论坛/开源蜂鸟E203/vivado 编译E203内核时IOstd 如何设置
开源蜂鸟E203 作者 发布于 2022-03-17 22:05(1688 天前) 4730 浏览
报错信息:
[DRC NSTD-1] Unspecified I/O Standard: 223 out of 223 logical ports use I/O standard (IOSTANDARD) value ‘DEFAULT’, instead of a user assigned specific value. This may cause I/O contention or incompatibility with the board power or connectivity affecting performance, signal integrity or in extreme cases cause damage to the device or the components to which it is connected. To correct this violation, specify all I/O standards. This design will fail to generate a bitstream unless all logical ports have a user specified I/O standard value defined. To allow bitstream creation with unspecified I/O standard values (not recommended), use this command: set_property SEVERITY {Warning} [get_drc_checks NSTD-1]. NOTE: When using the Vivado Runs infrastructure (e.g. launch_runs Tcl command), add this command to a .tcl file and add that file as a pre-hook for write_bitstream step for the implementation run. Problem ports: io_pads_gpioA_i_ival[31:0], io_pads_gpioA_o_oe[31:0], io_pads_gpioA_o_oval[31:0], io_pads_gpioB_i_ival[31:0], io_pads_gpioB_o_oe[31:0], io_pads_gpioB_o_oval[31:0], hfextclk, hfxoscen, io_pads_aon_erst_n_i_ival, io_pads_aon_pmu_dwakeup_n_i_ival, io_pads_aon_pmu_padrst_o_oval, io_pads_aon_pmu_vddpaden_o_oval, io_pads_bootrom_n_i_ival, io_pads_dbgmode0_n_i_ival, io_pads_dbgmode1_n_i_ival… and (the first 15 of 37 listed).
如果我用芯来提供的开发板mcu_200t,这里应该如何配置
