论坛/开源蜂鸟E203/Error: unable to resume hart 0 Error: dmstatus =0x004003a2
开源蜂鸟E203 作者 发布于 2022-03-24 11:01(1681 天前) 5652 浏览
将n101移植到MCU200T开发板上 并使用蜂鸟调试器调试在运行调试时在最后出现如下错误:
libusb1 09e75e98b4d9ea7909e8837b7a3f00dda4589dc3
For bug reports, read
DEPRECATED! use ‘adapter speed’ not ‘adapter_khz’
DEPRECATED! use ‘adapter driver’ not ‘interface’
DEPRECATED! use ‘ftdi vid_pid’ not ‘ftdi_vid_pid’
DEPRECATED! use ‘ftdi layout_init’ not ‘ftdi_layout_init’
DEPRECATED! use ‘ftdi layout_signal’ not ‘ftdi_layout_signal’
Info : auto-selecting first available session transport “jtag”. To override use ‘transport select ‘.
Info : clock speed 1000 kHz
Info : JTAG tap: riscv.cpu tap/device found: 0x11010a6d (mfg: 0x536 (Nuclei System Technology Co Ltd), part: 0x1010, ver: 0x1)
Info : datacount=4 progbufsize=2
Info : Examined RISC-V core; found 1 harts
Info : hart 0: XLEN=32, misa=0x40000014
Started by GNU MCU Eclipse
Info : Listening on port 6666 for tcl connections
Info : Listening on port 4444 for telnet connections
Info : accepting ‘gdb’ connection on tcp/3333
Warn : Prefer GDB command “target extended-remote :3333” instead of “target remote :3333”
semihosting is enabled
===== RISC-V Registers
(0) zero (/32)
(1) ra (/32)
(2) sp (/32)
(3) gp (/32)
(4) tp (/32)
(5) t0 (/32)
(6) t1 (/32)
(7) t2 (/32)
(8) fp (/32)
(9) s1 (/32)
(10) a0 (/32)
(11) a1 (/32)
(12) a2 (/32)
(13) a3 (/32)
(3923) marchid (/32)
(3924) mimpid (/32)
(3925) mhartid (/32)
(4161) priv (/8)
请问有人遇到相同的问题吗?感谢解答
