官方NICE协处理器代码详解(带注释)
报名编号:CICC2469
团队名称:AM
学校名称:广东工业大学
队伍成员:林贤、刘合明、谢泽铭
指导老师:郑欣、高怀恩
官方NICE协处理器代码详解(带注释)
话不多说,直接上代码
Github:https://github.com/LX-IC/e203_hbirdv2
记得star哦!
代码(带注释):
Copyright 2018-2020 Nuclei System Technology, Inc.
Licensed under the Apache License, Version 2.0 (the "License");
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an "AS IS" BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
// Designer : LZB
// Description:
// The Module to realize a simple NICE core
`include "e203_defines.v"
`ifdef E203_HAS_NICE//{
module e203_subsys_nice_core (
// System
input nice_clk ,
input nice_rst_n ,
output nice_active ,
output nice_mem_holdup ,
// output nice_rsp_err_irq ,
// Control cmd_req
input nice_req_valid ,
output nice_req_ready ,
input [`E203_XLEN-1:0] nice_req_inst ,
input [`E203_XLEN-1:0] nice_req_rs1 ,
input [`E203_XLEN-1:0] nice_req_rs2 ,
// Control cmd_rsp
output nice_rsp_valid ,
input nice_rsp_ready ,
output [`E203_XLEN-1:0] nice_rsp_rdat ,//写数据到寄存器
output nice_rsp_err ,
// Memory lsu_req
output nice_icb_cmd_valid ,
input nice_icb_cmd_ready ,
output [`E203_ADDR_SIZE-1:0] nice_icb_cmd_addr ,
output nice_icb_cmd_read ,
output [`E203_XLEN-1:0] nice_icb_cmd_wdata ,//写数据到内存
// output [`E203_XLEN_MW-1:0] nice_icb_cmd_wmask , //
output [1:0] nice_icb_cmd_size ,
// Memory lsu_rsp
input nice_icb_rsp_valid ,
output nice_icb_rsp_ready ,
input [`E203_XLEN-1:0] nice_icb_rsp_rdata ,
input nice_icb_rsp_err
localparam ROWBUF_DP = 4;
localparam ROWBUF_IDX_W = 2;
localparam ROW_IDX_W = 2;
localparam COL_IDX_W = 4;
localparam PIPE_NUM = 3;
// here we only use custom3:
// CUSTOM0 = 7'h0b, R type
// CUSTOM1 = 7'h2b, R tpye
// CUSTOM2 = 7'h5b, R type
// CUSTOM3 = 7'h7b, R type
// RISC-V format
// .insn r 0x33, 0, 0, a0, a1, a2 0: 00c58533[ ]+add [ ]+a0,a1,a2
// .insn i 0x13, 0, a0, a1, 13 4: 00d58513[ ]+addi[ ]+a0,a1,13
// .insn i 0x67, 0, a0, 10(a1) 8: 00a58567[ ]+jalr[ ]+a0,10 (a1)
// .insn s 0x3, 0, a0, 4(a1) c: 00458503[ ]+lb [ ]+a0,4(a1)
// .insn sb 0x63, 0, a0, a1, target 10: feb508e3[ ]+beq [ ]+a0,a1,0 target
// .insn sb 0x23, 0, a0, 4(a1) 14: 00a58223[ ]+sb [ ]+a0,4(a1)
// .insn u 0x37, a0, 0xfff 18: 00fff537[ ]+lui [ ]+a0,0xfff
// .insn uj 0x6f, a0, target 1c: fe5ff56f[ ]+jal [ ]+a0,0 target
// .insn ci 0x1, 0x0, a0, 4 20: 0511 [ ]+addi[ ]+a0,a0,4
// .insn cr 0x2, 0x8, a0, a1 22: 852e [ ]+mv [ ]+a0,a1
// .insn ciw 0x0, 0x0, a1, 1 24: 002c [ ]+addi[ ]+a1,sp,8
// .insn cb 0x1, 0x6, a1, target 26: dde9 [ ]+beqz[ ]+a1,0 target
// .insn cj 0x1, 0x5, target 28: bfe1 [ ]+j [ ]+0 targe
// decode
wire [6:0] opcode = {7{nice_req_valid}} & nice_req_inst[6:0];//提取opcode
wire [2:0] rv32_func3 = {3{nice_req_valid}} & nice_req_inst[14:12];//提取func3
wire [6:0] rv32_func7 = {7{nice_req_valid}} & nice_req_inst[31:25];//提取func7
// wire opcode_custom0 = (opcode == 7'b0001011);
// wire opcode_custom1 = (opcode == 7'b0101011);
// wire opcode_custom2 = (opcode == 7'b1011011);
wire opcode_custom3 = (opcode == 7'b1111011); //匹配opcode确认为custom3自定义指令
wire rv32_func3_000 = (rv32_func3 == 3'b000); //匹配func3
wire rv32_func3_001 = (rv32_func3 == 3'b001);
wire rv32_func3_010 = (rv32_func3 == 3'b010);
wire rv32_func3_011 = (rv32_func3 == 3'b011);
wire rv32_func3_100 = (rv32_func3 == 3'b100);
wire rv32_func3_101 = (rv32_func3 == 3'b101);
wire rv32_func3_110 = (rv32_func3 == 3'b110);
wire rv32_func3_111 = (rv32_func3 == 3'b111);
wire rv32_func7_0000000 = (rv32_func7 == 7'b0000000); //匹配func7
wire rv32_func7_0000001 = (rv32_func7 == 7'b0000001);
wire rv32_func7_0000010 = (rv32_func7 == 7'b0000010);
wire rv32_func7_0000011 = (rv32_func7 == 7'b0000011);
wire rv32_func7_0000100 = (rv32_func7 == 7'b0000100);
wire rv32_func7_0000101 = (rv32_func7 == 7'b0000101);
wire rv32_func7_0000110 = (rv32_func7 == 7'b0000110);
wire rv32_func7_0000111 = (rv32_func7 == 7'b0000111);
// custom3:
// Supported format: only R type here
// Supported instr:
// 1. custom3 lbuf: load data(in memory) to row_buf
// lbuf (a1)
// .insn r opcode, func3, func7, rd, rs1, rs2
// 2. custom3 sbuf: store data(in row_buf) to memory
// sbuf (a1)
// 3. custom3 acc rowsum: load data from memory(@a1), accumulate row datas and write back
// rowsum rd, a1, x0
wire custom3_lbuf = opcode_custom3 & rv32_func3_010 & rv32_func7_0000001; //判断是否是custom3_lbuf指令
wire custom3_sbuf = opcode_custom3 & rv32_func3_010 & rv32_func7_0000010;
wire custom3_rowsum = opcode_custom3 & rv32_func3_110 & rv32_func7_0000110;
// multi-cyc op
wire custom_multi_cyc_op = custom3_lbuf | custom3_sbuf | custom3_rowsum;//判断是否是协处理器指令
// need access memory
wire custom_mem_op = custom3_lbuf | custom3_sbuf | custom3_rowsum;//判断是否需要访问内存
// NICE FSM
parameter NICE_FSM_WIDTH = 2; //D触发器重载参数(DW)
parameter IDLE = 2'd0; //IDLE状态
parameter LBUF = 2'd1; //LBUF状态
parameter SBUF = 2'd2; //SBUF状态
parameter ROWSUM = 2'd3; //ROWSUM状态
wire [NICE_FSM_WIDTH-1:0] state_r; //D触发器的输出状态(当前状态)
wire [NICE_FSM_WIDTH-1:0] nxt_state; //D触发器的输入状态(下一状态)
wire [NICE_FSM_WIDTH-1:0] state_idle_nxt; //IDLE状态的下一状态
wire [NICE_FSM_WIDTH-1:0] state_lbuf_nxt; //LBUF状态的下一状态
wire [NICE_FSM_WIDTH-1:0] state_sbuf_nxt; //SBUF状态的下一状态
wire [NICE_FSM_WIDTH-1:0] state_rowsum_nxt; //ROWSUM状态的下一状态
wire nice_req_hsked;//与cpu握手成功,已接收指令
wire nice_rsp_hsked;//与cpu握手成功,已发送结果
wire nice_icb_rsp_hsked;//与memory握手成功,已接收反馈
wire illgel_instr = ~(custom_multi_cyc_op);//0:代表是协处理器指令 1:代表非协处理器指令
wire state_idle_exit_ena; //退出IDLE状态使能信号
wire state_lbuf_exit_ena; //退出LBUF状态使能信号
wire state_sbuf_exit_ena; //退出SBUF状态使能信号
wire state_rowsum_exit_ena; //退出ROWSUM状态使能信号
wire state_ena; //D触发器的状态使能输入
wire state_is_idle = (state_r == IDLE); //当前状态是IDLE状态
wire state_is_lbuf = (state_r == LBUF); //当前状态是LBUF状态
wire state_is_sbuf = (state_r == SBUF); //当前状态是SBUF状态
wire state_is_rowsum = (state_r == ROWSUM); //当前状态是ROWSUM状态
//如果当前状态是IDLE状态,与cpu握手成功,已接收指令,是协处理器指令,则使能退出IDLE状态使能信号
assign state_idle_exit_ena = state_is_idle & nice_req_hsked & ~illgel_instr;
//IDLE状态的下一状态是LBUF或SBUF或ROWSUM
assign state_idle_nxt = custom3_lbuf ? LBUF :
custom3_sbuf ? SBUF :
custom3_rowsum ? ROWSUM :
IDLE;
wire lbuf_icb_rsp_hsked_last; //LBUF指令操作结束信号
//如果当前状态是LBUF状态,LBUF指令操作结束信号为1,则使能退出LBUF状态使能信号
assign state_lbuf_exit_ena = state_is_lbuf & lbuf_icb_rsp_hsked_last;
//LBUF状态的下一状态是IDLE状态
assign state_lbuf_nxt = IDLE;
wire sbuf_icb_rsp_hsked_last; //SBUF指令操作结束信号
//如果当前状态是SBUF状态,SBUF指令操作结束信号为1,则使能退出SBUF状态使能信号
assign state_sbuf_exit_ena = state_is_sbuf & sbuf_icb_rsp_hsked_last;
//SBUF状态的下一状态是IDLE状态
assign state_sbuf_nxt = IDLE;
wire rowsum_done; //ROWSUM指令操作结束信号
//如果当前状态是ROWSUM状态,ROWSUM指令操作结束信号为1,则使能退出ROWSUM状态使能信号
assign state_rowsum_exit_ena = state_is_rowsum & rowsum_done;
//ROWSUM状态的下一状态是IDLE状态
assign state_rowsum_nxt = IDLE;
//D触发器的输入状态(下一状态)由退出的指令以及退出指令指定的下一状态确定
assign nxt_state = ({NICE_FSM_WIDTH{state_idle_exit_ena }} & state_idle_nxt )
| ({NICE_FSM_WIDTH{state_lbuf_exit_ena }} & state_lbuf_nxt )
| ({NICE_FSM_WIDTH{state_sbuf_exit_ena }} & state_sbuf_nxt )
| ({NICE_FSM_WIDTH{state_rowsum_exit_ena }} & state_rowsum_nxt )
//D触发器的状态使能输入由是否有指令退出使能
assign state_ena = state_idle_exit_ena | state_lbuf_exit_ena
| state_sbuf_exit_ena | state_rowsum_exit_ena;
//例化D触发器,重载参数DW,初始化状态为IDLE,当state_ena为1时,打一拍,nxt_state赋值给state_r,低电平复位(sirv_gnrl_dffs.v)
sirv_gnrl_dfflr #(NICE_FSM_WIDTH) state_dfflr (state_ena, nxt_state, state_r, nice_clk, nice_rst_n);
// instr EXU
wire [ROW_IDX_W-1:0] clonum = 2'b10; // fixed clonum 计数到2
//wire [COL_IDX_W-1:0] rownum;
//////////// 1. custom3_lbuf
wire [ROWBUF_IDX_W-1:0] lbuf_cnt_r; //D触发器的输出当前计数值
wire [ROWBUF_IDX_W-1:0] lbuf_cnt_nxt; //D触发器的输入下一计数值
wire lbuf_cnt_clr;//清零
wire lbuf_cnt_incr;//计数
wire lbuf_cnt_ena;//D触发器的输入计数使能
wire lbuf_cnt_last;//计到最后一个数
wire lbuf_icb_rsp_hsked;//IBUF状态下与memory握手成功,已接收反馈信号
wire nice_rsp_valid_lbuf;//IBUF状态的反馈cpu请求信号
wire nice_icb_cmd_valid_lbuf;//IBUF状态的读写memory请求信号
//LBUF状态下,与memory握手成功,已接收反馈,使能IBUF状态下与memory握手成功,已接收反馈信号
assign lbuf_icb_rsp_hsked = state_is_lbuf & nice_icb_rsp_hsked;
//计到最后一个数,IBUF状态下与memory握手成功,已接收反馈,使能LBUF指令操作结束信号,last, wait lbuf_cnt_last
assign lbuf_icb_rsp_hsked_last = lbuf_icb_rsp_hsked & lbuf_cnt_last;
//D触发器的输出当前计数值=2,则计到最后一个数
assign lbuf_cnt_last = (lbuf_cnt_r == clonum);
//与cpu握手成功,接收指令,指令是custom3_lbuf,则清零,first
assign lbuf_cnt_clr = custom3_lbuf & nice_req_hsked;
//IBUF状态下与memory握手成功,已接收反馈,但未计到最后一个数,则一直计数
assign lbuf_cnt_incr = lbuf_icb_rsp_hsked & ~lbuf_cnt_last;
//D触发器的输入计数使能由清零信号和计数信号确定
assign lbuf_cnt_ena = lbuf_cnt_clr | lbuf_cnt_incr;
//D触发器的输入下一计数值由清零信号和计数信号确定
assign lbuf_cnt_nxt = ({ROWBUF_IDX_W{lbuf_cnt_clr }} & {ROWBUF_IDX_W{1'b0}})
| ({ROWBUF_IDX_W{lbuf_cnt_incr}} & (lbuf_cnt_r + 1'b1) )
//例化D触发器,重载参数DW,初始化数为0,当lbuf_cnt_ena为1时,打一拍,lbuf_cnt_nxt赋值给lbuf_cnt_r,低电平复位(sirv_gnrl_dffs.v)
sirv_gnrl_dfflr #(ROWBUF_IDX_W) lbuf_cnt_dfflr (lbuf_cnt_ena, lbuf_cnt_nxt, lbuf_cnt_r, nice_clk, nice_rst_n);
// nice_rsp_valid wait for nice_icb_rsp_valid in LBUF
//LBUF状态下,与memory握手成功,已接收反馈,且计到最后一个数,则使能IBUF状态的反馈cpu请求信号,last, wait lbuf_cnt_last
assign nice_rsp_valid_lbuf = state_is_lbuf & lbuf_cnt_last & nice_icb_rsp_valid;
// nice_icb_cmd_valid sets when lbuf_cnt_r is not full in LBUF
//LBUF状态下,D触发器的输出当前计数值小于最大值,则使能IBUF状态的读写memory请求信号,first
assign nice_icb_cmd_valid_lbuf = (state_is_lbuf & (lbuf_cnt_r < clonum));
//////////// 2. custom3_sbuf
wire [ROWBUF_IDX_W-1:0] sbuf_cnt_r; //D触发器的输出当前计数值
wire [ROWBUF_IDX_W-1:0] sbuf_cnt_nxt; //D触发器的输入下一计数值
wire sbuf_cnt_clr;//清零
wire sbuf_cnt_incr;//计数
wire sbuf_cnt_ena;//D触发器的输入计数使能
wire sbuf_cnt_last;//计到最后一个数
wire sbuf_icb_cmd_hsked;//SBUF状态下与memory握手成功,已发送读写地址和数据信号
wire sbuf_icb_rsp_hsked;//SBUF状态下与memory握手成功,已接收反馈信号
wire nice_rsp_valid_sbuf;//SBUF状态的反馈cpu请求信号
wire nice_icb_cmd_valid_sbuf;//SBUF状态的读写memory请求信号
wire nice_icb_cmd_hsked;//与memory握手成功,已发送读写地址和数据
//SBUF状态下,与memory握手成功,已发送读写地址和数据,则使能SBUF状态下与memory握手成功,已发送读写地址和数据信号,second,第一个计数器开启
assign sbuf_icb_cmd_hsked = (state_is_sbuf | (state_is_idle & custom3_sbuf)) & nice_icb_cmd_hsked;
//SBUF状态下,与memory握手成功,已接收反馈,使能SBUF状态下与memory握手成功,已接收反馈信号,third,第二个计数器开启
assign sbuf_icb_rsp_hsked = state_is_sbuf & nice_icb_rsp_hsked;
//计到最后一个数,SBUF状态下与memory握手成功,已接收反馈,使能SBUF指令操作结束信号, last, wait sbuf_cnt_last
assign sbuf_icb_rsp_hsked_last = sbuf_icb_rsp_hsked & sbuf_cnt_last;
assign sbuf_cnt_last = (sbuf_cnt_r == clonum);
//assign sbuf_cnt_clr = custom3_sbuf & nice_req_hsked;
//SBUF指令操作结束,则清零,last, wait sbuf_cnt_last
assign sbuf_cnt_clr = sbuf_icb_rsp_hsked_last;
//SBUF状态下与memory握手成功,已接收反馈,但未计到最后一个数,则一直计数
assign sbuf_cnt_incr = sbuf_icb_rsp_hsked & ~sbuf_cnt_last;
assign sbuf_cnt_ena = sbuf_cnt_clr | sbuf_cnt_incr;
assign sbuf_cnt_nxt = ({ROWBUF_IDX_W{sbuf_cnt_clr }} & {ROWBUF_IDX_W{1'b0}})
| ({ROWBUF_IDX_W{sbuf_cnt_incr}} & (sbuf_cnt_r + 1'b1) )
//例化D触发器,重载参数DW,初始化数为0,当sbuf_cnt_ena为1时,打一拍,sbuf_cnt_nxt赋值给sbuf_cnt_r,低电平复位(sirv_gnrl_dffs.v)
sirv_gnrl_dfflr #(ROWBUF_IDX_W) sbuf_cnt_dfflr (sbuf_cnt_ena, sbuf_cnt_nxt, sbuf_cnt_r, nice_clk, nice_rst_n);
// nice_rsp_valid wait for nice_icb_rsp_valid in SBUF
//SBUF状态下,与memory握手成功,已接收反馈,且计到最后一个数,则使能SBUF状态的反馈cpu请求信号,last, wait sbuf_cnt_last
assign nice_rsp_valid_sbuf = state_is_sbuf & sbuf_cnt_last & nice_icb_rsp_valid;
wire [ROWBUF_IDX_W-1:0] sbuf_cmd_cnt_r; //D触发器的输出当前计数值
wire [ROWBUF_IDX_W-1:0] sbuf_cmd_cnt_nxt; //D触发器的输入下一计数值
wire sbuf_cmd_cnt_clr;//清零
wire sbuf_cmd_cnt_incr;//计数
wire sbuf_cmd_cnt_ena;//D触发器的输入计数使能
wire sbuf_cmd_cnt_last;//计到最后一个数
assign sbuf_cmd_cnt_last = (sbuf_cmd_cnt_r == clonum);
assign sbuf_cmd_cnt_clr = sbuf_icb_rsp_hsked_last;
//SBUF状态下与memory握手成功,已发送读写地址和数据信号,但未计到最后一个数,则一直计数
assign sbuf_cmd_cnt_incr = sbuf_icb_cmd_hsked & ~sbuf_cmd_cnt_last;
assign sbuf_cmd_cnt_ena = sbuf_cmd_cnt_clr | sbuf_cmd_cnt_incr;
assign sbuf_cmd_cnt_nxt = ({ROWBUF_IDX_W{sbuf_cmd_cnt_clr }} & {ROWBUF_IDX_W{1'b0}})
| ({ROWBUF_IDX_W{sbuf_cmd_cnt_incr}} & (sbuf_cmd_cnt_r + 1'b1) )
//例化D触发器,重载参数DW,初始化数为0,当sbuf_cmd_cnt_ena为1时,打一拍,sbuf_cmd_cnt_nxt赋值给sbuf_cmd_cnt_r,低电平复位(sirv_gnrl_dffs.v)
sirv_gnrl_dfflr #(ROWBUF_IDX_W) sbuf_cmd_cnt_dfflr (sbuf_cmd_cnt_ena, sbuf_cmd_cnt_nxt, sbuf_cmd_cnt_r, nice_clk, nice_rst_n);
// nice_icb_cmd_valid sets when sbuf_cmd_cnt_r is not full in SBUF
//SBUF状态下,D触发器的输出当前计数值sbuf_cmd_cnt_r小于等于最大值,sbuf_cnt_r不等于最大值,则使能SBUF状态的读写memory请求信号,first,also last, wait sbuf_cnt_last
assign nice_icb_cmd_valid_sbuf = (state_is_sbuf & (sbuf_cmd_cnt_r <= clonum) & (sbuf_cnt_r != clonum));
//////////// 3. custom3_rowsum
// rowbuf counter 跟前面一样,可以看成是ROWSUM状态下的第一个计数器
wire [ROWBUF_IDX_W-1:0] rowbuf_cnt_r; //D触发器的输出当前计数值
wire [ROWBUF_IDX_W-1:0] rowbuf_cnt_nxt; //D触发器的输入下一计数值
wire rowbuf_cnt_clr;//清零
wire rowbuf_cnt_incr;//计数
wire rowbuf_cnt_ena;//D触发器的输入计数使能
wire rowbuf_cnt_last;//计到最后一个数
wire rowbuf_icb_rsp_hsked;//ROWSUM状态下与memory握手成功,已接收反馈信号
wire rowbuf_rsp_hsked;//ROWSUM状态下与cpu握手成功,已发送结果信号
wire nice_rsp_valid_rowsum;//ROWSUM状态下的反馈cpu请求信号
//ROWSUM状态下的反馈cpu请求,cpu接收反馈,则使能ROWSUM状态下与cpu握手成功,已发送结果信号,last
assign rowbuf_rsp_hsked = nice_rsp_valid_rowsum & nice_rsp_ready;
//ROWSUM状态下,与memory握手成功,已接收反馈,使能ROWSUM状态下与memory握手成功,已接收反馈信号
assign rowbuf_icb_rsp_hsked = state_is_rowsum & nice_icb_rsp_hsked;
assign rowbuf_cnt_last = (rowbuf_cnt_r == clonum);
//计到最后一个数,且ROWSUM状态下与memory握手成功,已接收反馈信号,则清零
assign rowbuf_cnt_clr = rowbuf_icb_rsp_hsked & rowbuf_cnt_last;
//ROWSUM状态下与memory握手成功,已接收反馈信号,但未计到最后一个数,则一直计数
assign rowbuf_cnt_incr = rowbuf_icb_rsp_hsked & ~rowbuf_cnt_last;
assign rowbuf_cnt_ena = rowbuf_cnt_clr | rowbuf_cnt_incr;
assign rowbuf_cnt_nxt = ({ROWBUF_IDX_W{rowbuf_cnt_clr }} & {ROWBUF_IDX_W{1'b0}})
| ({ROWBUF_IDX_W{rowbuf_cnt_incr}} & (rowbuf_cnt_r + 1'b1))
//assign nice_icb_cmd_valid_rowbuf = (state_is_idle & custom3_rowsum)
// | (state_is_rowsum & (rowbuf_cnt_r <= clonum) & (clonum != 0))
//重载2,使能rowbuf_cnt_ena,打一拍,rowbuf_cnt_nxt赋值给rowbuf_cnt_r
sirv_gnrl_dfflr #(ROWBUF_IDX_W) rowbuf_cnt_dfflr (rowbuf_cnt_ena, rowbuf_cnt_nxt, rowbuf_cnt_r, nice_clk, nice_rst_n);
// recieve data buffer, to make sure rowsum ops come from registers
wire rcv_data_buf_ena;
wire rcv_data_buf_set;//ROWSUM状态下memory请求与反馈结束信号
wire rcv_data_buf_clr;//ROWSUM状态下cpu请求与反馈结束信号
wire rcv_data_buf_valid;
wire [`E203_XLEN-1:0] rcv_data_buf; //从memory读回的操作数
wire [ROWBUF_IDX_W-1:0] rcv_data_buf_idx;
wire [ROWBUF_IDX_W-1:0] rcv_data_buf_idx_nxt;
assign rcv_data_buf_set = rowbuf_icb_rsp_hsked;
assign rcv_data_buf_clr = rowbuf_rsp_hsked;
assign rcv_data_buf_ena = rcv_data_buf_clr | rcv_data_buf_set;
//ROWSUM状态下memory请求与反馈结束,cpu请求与反馈未结束,则rcv_data_buf_idx_nxt等于rowbuf_cnt_r
assign rcv_data_buf_idx_nxt = ({ROWBUF_IDX_W{rcv_data_buf_clr}} & {ROWBUF_IDX_W{1'b0}})
| ({ROWBUF_IDX_W{rcv_data_buf_set}} & rowbuf_cnt_r );
//重载1,使能1,打一拍,rcv_data_buf_ena赋值给rcv_data_buf_valid
sirv_gnrl_dfflr #(1) rcv_data_buf_valid_dfflr (1'b1, rcv_data_buf_ena, rcv_data_buf_valid, nice_clk, nice_rst_n);
//重载32,使能rcv_data_buf_ena,打一拍,nice_icb_rsp_rdata赋值给rcv_data_buf
sirv_gnrl_dfflr #(`E203_XLEN) rcv_data_buf_dfflr (rcv_data_buf_ena, nice_icb_rsp_rdata, rcv_data_buf, nice_clk, nice_rst_n);
//重载2,使能rcv_data_buf_ena,打一拍,rcv_data_buf_idx_nxt赋值给rcv_data_buf_idx
sirv_gnrl_dfflr #(ROWBUF_IDX_W) rowbuf_cnt_d_dfflr (rcv_data_buf_ena, rcv_data_buf_idx_nxt, rcv_data_buf_idx, nice_clk, nice_rst_n);
// rowsum accumulator
wire [`E203_XLEN-1:0] rowsum_acc_r;//当前操作数
wire [`E203_XLEN-1:0] rowsum_acc_nxt;//下一操作数
wire [`E203_XLEN-1:0] rowsum_acc_adder;//操作数和
wire rowsum_acc_ena;
wire rowsum_acc_set;//第一个操作数状态使能
wire rowsum_acc_flg;//非第一个操作数状态使能
wire nice_icb_cmd_valid_rowsum;
wire [`E203_XLEN-1:0] rowsum_res;//操作数总和
assign rowsum_acc_set = rcv_data_buf_valid & (rcv_data_buf_idx == {ROWBUF_IDX_W{1'b0}});
assign rowsum_acc_flg = rcv_data_buf_valid & (rcv_data_buf_idx != {ROWBUF_IDX_W{1'b0}});
//将从memory读回的操作数与当前操作数相加
assign rowsum_acc_adder = rcv_data_buf + rowsum_acc_r;
assign rowsum_acc_ena = rowsum_acc_set | rowsum_acc_flg;
//如果是第一个操作数,则rowsum_acc_nxt等于从memory读回的操作数,否则则等于目前的操作数和
assign rowsum_acc_nxt = ({`E203_XLEN{rowsum_acc_set}} & rcv_data_buf)
| ({`E203_XLEN{rowsum_acc_flg}} & rowsum_acc_adder)
//重载32,使能rowsum_acc_ena,打一拍,rowsum_acc_nxt赋值给rowsum_acc_r
sirv_gnrl_dfflr #(`E203_XLEN) rowsum_acc_dfflr (rowsum_acc_ena, rowsum_acc_nxt, rowsum_acc_r, nice_clk, nice_rst_n);
assign rowsum_done = state_is_rowsum & nice_rsp_hsked;//ROWSUM指令操作结束
assign rowsum_res = rowsum_acc_r;//操作数总和
// rowsum finishes when the last acc data is added to rowsum_acc_r
//操作完,nice_rsp_valid_rowsum打开准备反馈给cpu
assign nice_rsp_valid_rowsum = state_is_rowsum & (rcv_data_buf_idx == clonum) & ~rowsum_acc_flg;
// nice_icb_cmd_valid sets when rcv_data_buf_idx is not full in LBUF
//还没从内存取完数,nice_icb_cmd_valid_rowsum一直打开
assign nice_icb_cmd_valid_rowsum = state_is_rowsum & (rcv_data_buf_idx < clonum) & ~rowsum_acc_flg;
//////////// rowbuf //lbuf和rowsum写rowbuf,sbuf读rowbuf,rowsum写入rowbuf的是列加运算的结果
// rowbuf access list:
// 1. lbuf will write to rowbuf, write data comes from memory, data length is defined by clonum
// 2. sbuf will read from rowbuf, and store it to memory, data length is defined by clonum
// 3. rowsum will accumulate data, and store to rowbuf, data length is defined by clonum
wire [`E203_XLEN-1:0] rowbuf_r [ROWBUF_DP-1:0];//16个32位宽的读数据[31:0][3:0]
wire [`E203_XLEN-1:0] rowbuf_wdat [ROWBUF_DP-1:0];//16个32位宽的写数据
wire [ROWBUF_DP-1:0] rowbuf_we;//4位宽的数据,D触发器的使能信号
wire [ROWBUF_IDX_W-1:0] rowbuf_idx_mux; //2位宽的数据
wire [`E203_XLEN-1:0] rowbuf_wdat_mux; //32位宽的数据
wire rowbuf_wr_mux;
//wire [ROWBUF_IDX_W-1:0] sbuf_idx;
// lbuf write to rowbuf
wire [ROWBUF_IDX_W-1:0] lbuf_idx = lbuf_cnt_r; //写入rowbuf的序号
wire lbuf_wr = lbuf_icb_rsp_hsked; //使能lbuf写rowbuf信号
wire [`E203_XLEN-1:0] lbuf_wdata = nice_icb_rsp_rdata;
// rowsum write to rowbuf(column accumulated data)
wire [ROWBUF_IDX_W-1:0] rowsum_idx = rcv_data_buf_idx; //写入rowbuf的序号
wire rowsum_wr = rcv_data_buf_valid; //使能rowsum写rowbuf信号
wire [`E203_XLEN-1:0] rowsum_wdata = rowbuf_r[rowsum_idx] + rcv_data_buf;//列加运算,每行元素分三个D触发器储存
// rowbuf write mux
//选择写入的数据
assign rowbuf_wdat_mux = ({`E203_XLEN{lbuf_wr }} & lbuf_wdata )
| ({`E203_XLEN{rowsum_wr}} & rowsum_wdata)
//选择写入的指令信号
assign rowbuf_wr_mux = lbuf_wr | rowsum_wr;
//选择写入rowbuf的序号
assign rowbuf_idx_mux = ({ROWBUF_IDX_W{lbuf_wr }} & lbuf_idx )
| ({ROWBUF_IDX_W{rowsum_wr}} & rowsum_idx)
// rowbuf inst //实例化4个D触发器作为rowbuf
genvar i;
generate
for (i=0; i1) begin:gen_rowbuf
//确定写入的序号和使能信号
assign rowbuf_we[i] = (rowbuf_wr_mux & (rowbuf_idx_mux == i[ROWBUF_IDX_W-1:0]))
//确定写入的数据
assign rowbuf_wdat[i] = ({`E203_XLEN{rowbuf_we[i]}} & rowbuf_wdat_mux )
//生成触发器,并把数据写入,重载32,使能rowbuf_we[i],打一拍,rowbuf_wdat[i]赋值给rowbuf_r[i]
sirv_gnrl_dfflr #(`E203_XLEN) rowbuf_dfflr (rowbuf_we[i], rowbuf_wdat[i], rowbuf_r[i], nice_clk, nice_rst_n);
endgenerate
//////////// mem aacess addr management
wire [`E203_XLEN-1:0] maddr_acc_r;
assign nice_icb_cmd_hsked = nice_icb_cmd_valid & nice_icb_cmd_ready; //与memory握手成功,已发送读写地址和数据
// custom3_lbuf
//wire [`E203_XLEN-1:0] lbuf_maddr = state_is_idle ? nice_req_rs1 : maddr_acc_r ;
//LBUF状态下,操作memory使能信号
wire lbuf_maddr_ena = (state_is_idle & custom3_lbuf & nice_icb_cmd_hsked)
| (state_is_lbuf & nice_icb_cmd_hsked)
// custom3_sbuf
//wire [`E203_XLEN-1:0] sbuf_maddr = state_is_idle ? nice_req_rs1 : maddr_acc_r ;
//SBUF状态下,操作memory使能信号
wire sbuf_maddr_ena = (state_is_idle & custom3_sbuf & nice_icb_cmd_hsked)
| (state_is_sbuf & nice_icb_cmd_hsked)
// custom3_rowsum
//wire [`E203_XLEN-1:0] rowsum_maddr = state_is_idle ? nice_req_rs1 : maddr_acc_r ;
//ROWSUM状态下,操作memory使能信号
wire rowsum_maddr_ena = (state_is_idle & custom3_rowsum & nice_icb_cmd_hsked)
| (state_is_rowsum & nice_icb_cmd_hsked)
// maddr acc
//wire maddr_incr = lbuf_maddr_ena | sbuf_maddr_ena | rowsum_maddr_ena | rbuf_maddr_ena;
wire maddr_ena = lbuf_maddr_ena | sbuf_maddr_ena | rowsum_maddr_ena;
wire maddr_ena_idle = maddr_ena & state_is_idle;//当状态为IDLE时先取出第一个内存地址,即从指令读取的内存地址
//nice_req_rs1是从指令读取的内存地址,之后从memory每取一个数,内存地址要加4,因为每一个数是32位,32/8=4
wire [`E203_XLEN-1:0] maddr_acc_op1 = maddr_ena_idle ? nice_req_rs1 : maddr_acc_r; // not reused
wire [`E203_XLEN-1:0] maddr_acc_op2 = maddr_ena_idle ? `E203_XLEN'h4 : `E203_XLEN'h4;
wire [`E203_XLEN-1:0] maddr_acc_next = maddr_acc_op1 + maddr_acc_op2;
wire maddr_acc_ena = maddr_ena;
//重载32,使能maddr_acc_ena,打一拍,maddr_acc_next赋值给maddr_acc_r
sirv_gnrl_dfflr #(`E203_XLEN) maddr_acc_dfflr (maddr_acc_ena, maddr_acc_next, maddr_acc_r, nice_clk, nice_rst_n);
// Control cmd_req
assign nice_req_hsked = nice_req_valid & nice_req_ready;
assign nice_req_ready = state_is_idle & (custom_mem_op ? nice_icb_cmd_ready : 1'b1);
// Control cmd_rsp
assign nice_rsp_hsked = nice_rsp_valid & nice_rsp_ready;
assign nice_icb_rsp_hsked = nice_icb_rsp_valid & nice_icb_rsp_ready;
assign nice_rsp_valid = nice_rsp_valid_rowsum | nice_rsp_valid_sbuf | nice_rsp_valid_lbuf;
assign nice_rsp_rdat = {`E203_XLEN{state_is_rowsum}} & rowsum_res;
// memory access bus error
//assign nice_rsp_err_irq = (nice_icb_rsp_hsked & nice_icb_rsp_err)
// | (nice_req_hsked & illgel_instr)
assign nice_rsp_err = (nice_icb_rsp_hsked & nice_icb_rsp_err);//与memory握手成功,并从memory接收的反馈即为给cpu的反馈
// Memory lsu
// memory access list:
// 1. In IDLE, custom_mem_op will access memory(lbuf/sbuf/rowsum)
// 2. In LBUF, it will read from memory as long as lbuf_cnt_r is not full
// 3. In SBUF, it will write to memory as long as sbuf_cnt_r is not full
// 3. In ROWSUM, it will read from memory as long as rowsum_cnt_r is not full
//assign nice_icb_rsp_ready = state_is_ldst_rsp & nice_rsp_ready;
// rsp always ready
assign nice_icb_rsp_ready = 1'b1; //时刻准备接收memory反馈
wire [ROWBUF_IDX_W-1:0] sbuf_idx = sbuf_cmd_cnt_r;
//使能memory请求信号
assign nice_icb_cmd_valid = (state_is_idle & nice_req_valid & custom_mem_op)
//(状态idle且命令有效)为寄存器1,否则为maddr_acc_r
assign nice_icb_cmd_addr = (state_is_idle & custom_mem_op) ? nice_req_rs1 :
maddr_acc_r;
//(状态idle且为lbuf或rowsumz指令,为1,为sbuf指令,为0),或者为sbuf状态为0,否则为1,0为写,1为读
assign nice_icb_cmd_read = (state_is_idle & custom_mem_op) ? (custom3_lbuf | custom3_rowsum) :
state_is_sbuf ? 1'b0 :
1'b1;
//(状态idle,sbuf指令)或subf状态,为rowbuf_r[sbuf_idx],否则为0
assign nice_icb_cmd_wdata = (state_is_idle & custom3_sbuf) ? rowbuf_r[sbuf_idx] :
state_is_sbuf ? rowbuf_r[sbuf_idx] :
`E203_XLEN'b0;
//assign nice_icb_cmd_wmask = {`sirv_XLEN_MW{custom3_sbuf}} & 4'b1111;
assign nice_icb_cmd_size = 2'b10;//2: 代表4字节32位数据
assign nice_mem_holdup = state_is_lbuf | state_is_sbuf | state_is_rowsum; //独占内存信号
// nice_active
assign nice_active = state_is_idle ? nice_req_valid : 1'b1;//nice是否在工作
endmodule
`endif//}
参考文章:https://blog.csdn.net/qq_43858116/article/details/125497749
回复2
浏览7337
发布2023-04-16 15:18
