论坛/开源蜂鸟E203/E203乘法模块注解
E203乘法模块注解
开源蜂鸟E203 作者 KARRY_WANG 发布于 2023-05-31 23:42(1268 天前) 5814 浏览
Copyright 2018-2020 Nuclei System Technology, Inc.
Licensed under the Apache License, Version 2.0 (the “License”);
you may not use this file except in compliance with the License.
You may obtain a copy of the License at
 http://www.apache.org/licenses/LICENSE-2.0
Unless required by applicable law or agreed to in writing, software
distributed under the License is distributed on an “AS IS” BASIS,
WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied.
See the License for the specific language governing permissions and
limitations under the License.
// Designer : Bob Hu
// Description:
// This module to implement the 17cycles MUL and 33 cycles DIV unit, which is mostly
// share the datapath with ALU_DPATH module to save gatecount to mininum
`include “e203_defines.v”
`ifdef E203_SUPPORT_MULDIV //{
module e203_exu_alu_muldiv(
input mdv_nob2b,
// The Issue Handshake Interface to MULDIV
input muldiv_i_valid, // Handshake valid
output muldiv_i_ready, // Handshake ready
input [E203_XLEN-1:0] muldiv_i_rs1, input [E203_XLEN-1:0] muldiv_i_rs2,
input [E203_XLEN-1:0] muldiv_i_imm, input [E203_DECINFO_MULDIV_WIDTH-1:0] muldiv_i_info,
input [`E203_ITAG_WIDTH-1:0] muldiv_i_itag,
output muldiv_i_longpipe,
input flush_pulse,
// The MULDIV Write-Back/Commit Interface
output muldiv_o_valid, // Handshake valid
input muldiv_o_ready, // Handshake ready
output [`E203_XLEN-1:0] muldiv_o_wbck_wdat,
output muldiv_o_wbck_err,
// There is no exception cases for MULDIV, so no addtional cmt signals
// To share the ALU datapath, generate interface to ALU
// The operands and info to ALU
output [E203_MULDIV_ADDER_WIDTH-1:0] muldiv_req_alu_op1, output [E203_MULDIV_ADDER_WIDTH-1:0] muldiv_req_alu_op2,
output [E203_MULDIV_ADDER_WIDTH-1:0] muldiv_req_alu_op3, output muldiv_req_alu_add, output muldiv_req_alu_sub, output mul_exu_alu_addsub, input [E203_MULDIV_ADDER_WIDTH-1:0] muldiv_req_alu_res,
 // The Shared-Buffer interface to ALU-Shared-Buffer
output muldiv_sbf_0_ena,
output [33-1:0] muldiv_sbf_0_nxt,
input [33-1:0] muldiv_sbf_0_r,
output muldiv_sbf_1_ena,
output [33-1:0] muldiv_sbf_1_nxt,
input [33-1:0] muldiv_sbf_1_r,
output i_op_mul,
output mul_op1_sub,
output mul_op2_sub,
input clk,
input rst_n
wire muldiv_i_hsked = muldiv_i_valid & muldiv_i_ready;
wire muldiv_o_hsked = muldiv_o_valid & muldiv_o_ready;
wire flushed_r;
wire flushed_set = flush_pulse;
wire flushed_clr = muldiv_o_hsked & (~flush_pulse);
wire flushed_ena = flushed_set | flushed_clr;
wire flushed_nxt = flushed_set | (~flushed_clr);
sirv_gnrl_dfflr #(1) flushed_dfflr (flushed_ena, flushed_nxt, flushed_r, clk, rst_n);
//从 Info Bus中取出相关信息
wire i_mul = muldiv_i_info[E203_DECINFO_MULDIV_MUL ];// We treat this as signed X signed wire i_mulh = muldiv_i_info[E203_DECINFO_MULDIV_MULH ];
wire i_mulhsu = muldiv_i_info[E203_DECINFO_MULDIV_MULHSU]; wire i_mulhu = muldiv_i_info[E203_DECINFO_MULDIV_MULHU ];
wire i_div = muldiv_i_info[E203_DECINFO_MULDIV_DIV ]; wire i_divu = muldiv_i_info[E203_DECINFO_MULDIV_DIVU ];
wire i_rem = muldiv_i_info[E203_DECINFO_MULDIV_REM ]; wire i_remu = muldiv_i_info[E203_DECINFO_MULDIV_REMU ];
// If it is flushed then it is not back2back real case
wire i_b2b = muldiv_i_info[`E203_DECINFO_MULDIV_B2B ] & (~flushed_r) & (~mdv_nob2b);
wire back2back_seq = i_b2b;
//对操作数进行符号位扩展
wire mul_rs1_sign = (i_mulhu) ? 1’b0 : muldiv_i_rs1[E203_XLEN-1]; wire mul_rs2_sign = (i_mulhsu | i_mulhu) ? 1'b0 : muldiv_i_rs2[E203_XLEN-1];
wire [32:0] mul_op1 = {mul_rs1_sign, muldiv_i_rs1};
wire [32:0] mul_op2 = {mul_rs2_sign, muldiv_i_rs2};
//译码出是乘法还是除法操作
assign i_op_mul = i_mul | i_mulh | i_mulhsu | i_mulhu;
wire i_op_div = i_div | i_divu | i_rem | i_remu;
//使用统一的状态机控制多周期乘法或除法操作
// Implement the state machine for
// (1) The MUL instructions
// (2) The DIV instructions
localparam MULDIV_STATE_WIDTH = 3;
wire [MULDIV_STATE_WIDTH-1:0] muldiv_state_nxt;
wire [MULDIV_STATE_WIDTH-1:0] muldiv_state_r;
wire muldiv_state_ena;
// State 0: The 0th state, means this is the 1 cycle see the operand inputs
localparam MULDIV_STATE_0TH = 3’d0;
// State 1: Executing the instructions
localparam MULDIV_STATE_EXEC = 3’d1;
// State 2: Div check if need correction
localparam MULDIV_STATE_REMD_CHCK = 3’d2;
// State 3: Quotient correction
localparam MULDIV_STATE_QUOT_CORR = 3’d3;
// State 4: Reminder correction
localparam MULDIV_STATE_REMD_CORR = 3’d4;
wire [MULDIV_STATE_WIDTH-1:0] state_0th_nxt;
wire [MULDIV_STATE_WIDTH-1:0] state_exec_nxt;
wire [MULDIV_STATE_WIDTH-1:0] state_remd_chck_nxt;
wire [MULDIV_STATE_WIDTH-1:0] state_quot_corr_nxt;
wire [MULDIV_STATE_WIDTH-1:0] state_remd_corr_nxt;
wire state_0th_exit_ena;
wire state_exec_exit_ena;
wire state_remd_chck_exit_ena;
wire state_quot_corr_exit_ena;
wire state_remd_corr_exit_ena;
wire special_cases;
wire muldiv_i_valid_nb2b = muldiv_i_valid & (~back2back_seq) & (~special_cases);
// Define some common signals and reused later to save gatecounts
wire muldiv_sta_is_0th = (muldiv_state_r == MULDIV_STATE_0TH );
wire muldiv_sta_is_exec = (muldiv_state_r == MULDIV_STATE_EXEC );
wire muldiv_sta_is_remd_chck = (muldiv_state_r == MULDIV_STATE_REMD_CHCK );
wire muldiv_sta_is_quot_corr = (muldiv_state_r == MULDIV_STATE_QUOT_CORR );
wire muldiv_sta_is_remd_corr = (muldiv_state_r == MULDIV_STATE_REMD_CORR );
  // **** If the current state is 0th,
      // If a new instruction come (non back2back), next state is MULDIV_STATE_EXEC
assign state_0th_exit_ena = muldiv_sta_is_0th & muldiv_i_valid_nb2b & (~flush_pulse);
assign state_0th_nxt = MULDIV_STATE_EXEC;
  // **** If the current state is exec,
wire div_need_corrct;
wire mul_exec_last_cycle;
wire div_exec_last_cycle;
wire exec_last_cycle;
assign state_exec_exit_ena = muldiv_sta_is_exec & ((
// If it is the last cycle (16th or 32rd cycles),
exec_last_cycle
// If it is div op, then jump to DIV_CHECK state
& (i_op_div ? 1’b1
// If it is not div-need-correction, then jump to 0th
: muldiv_o_hsked))
| flush_pulse);
assign state_exec_nxt =
flush_pulse ? MULDIV_STATE_0TH :
i_op_div ? MULDIV_STATE_REMD_CHCK
: MULDIV_STATE_0TH
  // **** If the current state is REMD_CHCK,
      // If it is div-need-correction, then jump to QUOT_CORR state
      //   otherwise jump to the 0th
assign state_remd_chck_exit_ena = (muldiv_sta_is_remd_chck & (
(div_need_corrct ? 1’b1
: muldiv_o_hsked)
| flush_pulse )) ;
assign state_remd_chck_nxt = flush_pulse ? MULDIV_STATE_0TH :
div_need_corrct ? MULDIV_STATE_QUOT_CORR
: MULDIV_STATE_0TH;
  // **** If the current state is QUOT_CORR,
      // Always jump to REMD_CORR state
assign state_quot_corr_exit_ena = (muldiv_sta_is_quot_corr & (flush_pulse | 1’b1));
assign state_quot_corr_nxt = flush_pulse ? MULDIV_STATE_0TH : MULDIV_STATE_REMD_CORR;
  // **** If the current state is REMD_CORR,
          // Then jump to 0th
assign state_remd_corr_exit_ena = (muldiv_sta_is_remd_corr & (flush_pulse | muldiv_o_hsked));
assign state_remd_corr_nxt = flush_pulse ? MULDIV_STATE_0TH : MULDIV_STATE_0TH;
// The state will only toggle when each state is meeting the condition to exit
assign muldiv_state_ena = state_0th_exit_ena
| state_exec_exit_ena
// The next-state is onehot mux to select different entries
assign muldiv_state_nxt =
({MULDIV_STATE_WIDTH{state_0th_exit_ena }} & state_0th_nxt )
| ({MULDIV_STATE_WIDTH{state_exec_exit_ena }} & state_exec_nxt )
| ({MULDIV_STATE_WIDTH{state_remd_chck_exit_ena}} & state_remd_chck_nxt)
| ({MULDIV_STATE_WIDTH{state_quot_corr_exit_ena}} & state_quot_corr_nxt)
| ({MULDIV_STATE_WIDTH{state_remd_corr_exit_ena}} & state_remd_corr_nxt)
sirv_gnrl_dfflr #(MULDIV_STATE_WIDTH) muldiv_state_dfflr (muldiv_state_ena, muldiv_state_nxt, muldiv_state_r, clk, rst_n);
wire state_exec_enter_ena = muldiv_state_ena & (muldiv_state_nxt == MULDIV_STATE_EXEC);
localparam EXEC_CNT_W = 6;
localparam EXEC_CNT_1 = 6’d1 ;
localparam EXEC_CNT_16 = 6’d8; //指示乘法需要总共9个迭代时钟周期
localparam EXEC_CNT_32 = 6’d32; //指示除法需要总共33个迭代时钟周期
//实现迭代周期的计数
wire[EXEC_CNT_W-1:0] exec_cnt_r;
wire exec_cnt_set = state_exec_enter_ena;
wire exec_cnt_inc = muldiv_sta_is_exec & (~exec_last_cycle);
wire exec_cnt_ena = exec_cnt_inc | exec_cnt_set;
// When set, the counter is set to 1, because the 0th state also counted as 0th cycle
wire[EXEC_CNT_W-1:0] exec_cnt_nxt = exec_cnt_set ? EXEC_CNT_1 : (exec_cnt_r + 1’b1);
sirv_gnrl_dfflr #(EXEC_CNT_W) exec_cnt_dfflr (exec_cnt_ena, exec_cnt_nxt, exec_cnt_r, clk, rst_n);
// The exec state is the last cycle when the exec_cnt_r is reaching the last cycle (16 or 32cycles)
wire cycle_0th = muldiv_sta_is_0th;
wire cycle_16th = (exec_cnt_r == EXEC_CNT_16);
wire cycle_32nd = (exec_cnt_r == EXEC_CNT_32);
assign mul_exec_last_cycle = cycle_16th;
assign div_exec_last_cycle = cycle_32nd;
assign exec_last_cycle = i_op_mul ? mul_exec_last_cycle : div_exec_last_cycle;
// Use booth-4 algorithm to conduct the multiplication
wire [32:0] part_prdt_hi_r;
wire [32:0] part_prdt_lo_r;
wire [32:0] part_prdt_hi_nxt;
wire [32:0] part_prdt_lo_nxt;
wire part_prdt_sft1_r;
wire [2:0] booth_code1 = cycle_0th ? {muldiv_i_rs1[1:0],1’b0} //第一个booth_code,低位补0
: cycle_16th ? {mul_rs1_sign,part_prdt_lo_r[0],part_prdt_sft1_r} //最后一个booth_code,高位为符号位扩展
: {part_prdt_lo_r[1:0],part_prdt_sft1_r};
wire [2:0] booth_code2 = cycle_0th ? {muldiv_i_rs1[3:1]} //第二个booth_code
: cycle_16th ? {mul_rs1_sign,mul_rs1_sign,mul_rs1_sign} //最后一个booth_code,高位为符号位扩展
: {part_prdt_lo_r[3:1]};
//booth_code == 3’b000 = 0
//booth_code == 3’b001 = 1
//booth_code == 3’b010 = 1
//booth_code == 3’b011 = 2
//booth_code == 3’b100 = -2
//booth_code == 3’b101 = -1
//booth_code == 3’b110 = -1
//booth_code == 3’b111 = -0
wire booth_sel_zero1 = (booth_code1 == 3’b000) | (booth_code1 == 3’b111);
wire booth_sel_two1 = (booth_code1 == 3’b011) | (booth_code1 == 3’b100);
wire booth_sel_one1 = (~booth_sel_zero1) & (~booth_sel_two1);
wire booth_sel_sub1 = booth_code1[2];
wire booth_sel_zero2 = (booth_code2 == 3’b000) | (booth_code2 == 3’b111);
wire booth_sel_two2 = (booth_code2 == 3’b011) | (booth_code2 == 3’b100);
wire booth_sel_one2 = (~booth_sel_zero2) & (~booth_sel_two2);
wire booth_sel_sub2 = booth_code2[2];
// 35 bits adder needed
wire [E203_MULDIV_ADDER_WIDTH-1:0] mul_exe_alu_res = muldiv_req_alu_res; //生成乘法每次迭代所需加法或者减法的操作数,使用and-or的编码方式产生并行选择器 wire [E203_MULDIV_ADDER_WIDTH-1:0] mul_exe_alu_op2 =
({E203_MULDIV_ADDER_WIDTH{booth_sel_zero1}} &E203_MULDIV_ADDER_WIDTH’b0)
| ({E203_MULDIV_ADDER_WIDTH{booth_sel_one1 }} & {mul_rs2_sign,mul_rs2_sign,mul_rs2_sign,muldiv_i_rs2}) | ({E203_MULDIV_ADDER_WIDTH{booth_sel_two1 }} & {mul_rs2_sign,mul_rs2_sign,muldiv_i_rs2,1’b0})
wire [E203_MULDIV_ADDER_WIDTH-1:0] mul_exe_alu_op3 = ({E203_MULDIV_ADDER_WIDTH{booth_sel_zero2}} & E203_MULDIV_ADDER_WIDTH'b0) | ({E203_MULDIV_ADDER_WIDTH{booth_sel_one2 }} & {mul_rs2_sign,muldiv_i_rs2,{2{1’b0}}})
| ({E203_MULDIV_ADDER_WIDTH{booth_sel_two2 }} & {muldiv_i_rs2,{3{1'b0}}}) ; wire [E203_MULDIV_ADDER_WIDTH-1:0] mul_exe_alu_op1 =
cycle_0th ? `E203_MULDIV_ADDER_WIDTH’b0 : {part_prdt_hi_r[32],part_prdt_hi_r[32],part_prdt_hi_r};
//生成乘法每次迭代所需进行加法或者减法的指示信号
assign mul_op1_sub = booth_sel_sub1;
assign mul_op2_sub = booth_sel_sub2;
wire mul_exe_alu_add = (~booth_sel_sub1) & (~booth_sel_sub2);
wire mul_exe_alu_sub = booth_sel_sub1 & booth_sel_sub2;
assign mul_exu_alu_addsub = booth_sel_sub1 ^ booth_sel_sub2;
assign part_prdt_hi_nxt = {mul_exe_alu_res[34],mul_exe_alu_res[34],mul_exe_alu_res[34:4]}; //计算结果的部分积,高33位
assign part_prdt_lo_nxt = {mul_exe_alu_res[3:0], //计算结果的部分积,低2位,拼接上次结果的高31位
(cycle_0th ? {mul_rs1_sign,muldiv_i_rs1[31:4]} : part_prdt_lo_r[32:4])
wire part_prdt_sft1_nxt = cycle_0th ? muldiv_i_rs1[3] : part_prdt_lo_r[3];
wire mul_exe_cnt_set = exec_cnt_set & i_op_mul;
wire mul_exe_cnt_inc = exec_cnt_inc & i_op_mul;
wire part_prdt_hi_ena = mul_exe_cnt_set | mul_exe_cnt_inc | state_exec_exit_ena;
wire part_prdt_lo_ena = part_prdt_hi_ena;
sirv_gnrl_dfflr #(1) part_prdt_sft1_dfflr (part_prdt_lo_ena, part_prdt_sft1_nxt, part_prdt_sft1_r, clk, rst_n);
// This mul_res is not back2back case, so directly from the adder result
wire[`E203_XLEN-1:0] mul_res = i_mul ? part_prdt_lo_r[32:1] : mul_exe_alu_res[31:0];
// The Divider Implementation, using the non-restoring signed division
wire [32:0] part_remd_r;
wire [32:0] part_quot_r;
wire div_rs1_sign = (i_divu | i_remu) ? 1’b0 : muldiv_i_rs1[E203_XLEN-1]; wire div_rs2_sign = (i_divu | i_remu) ? 1'b0 : muldiv_i_rs2[E203_XLEN-1];
wire [65:0] dividend = {{33{div_rs1_sign}}, div_rs1_sign, muldiv_i_rs1};
wire [33:0] divisor = {div_rs2_sign, div_rs2_sign, muldiv_i_rs2};
wire quot_0cycl = (dividend[65] ^ divisor[33]) ? 1’b0 : 1’b1;// If the sign(s0)!=sign(d), then set q_1st = -1
wire [66:0] dividend_lsft1 = {dividend[65:0],quot_0cycl};
wire prev_quot = cycle_0th ? quot_0cycl : part_quot_r[0];
wire part_remd_sft1_r;
// 34 bits adder needed
wire [33:0] div_exe_alu_res = muldiv_req_alu_res[33:0];
//生成除法每次迭代所需加法或者减法的操作数
wire [33:0] div_exe_alu_op1 = cycle_0th ? dividend_lsft1[66:33] : {part_remd_sft1_r, part_remd_r[32:0]};
wire [33:0] div_exe_alu_op2 = divisor;
wire div_exe_alu_add = (~prev_quot);
wire div_exe_alu_sub = prev_quot ;
wire current_quot = (div_exe_alu_res[33] ^ divisor[33]) ? 1’b0 : 1’b1;
wire [66:0] div_exe_part_remd;
assign div_exe_part_remd[66:33] = div_exe_alu_res;
assign div_exe_part_remd[32: 0] = cycle_0th ? dividend_lsft1[32:0] : part_quot_r[32:0];
wire [67:0] div_exe_part_remd_lsft1 = {div_exe_part_remd[66:0],current_quot};
wire part_remd_ena;
// Since the part_remd_r is only save 33bits (after left shifted), so the adder result MSB bit we need to save
// it here, which will be used at next round
sirv_gnrl_dfflr #(1) part_remd_sft1_dfflr (part_remd_ena, div_exe_alu_res[32], part_remd_sft1_r, clk, rst_n);
wire div_exe_cnt_set = exec_cnt_set & i_op_div;
wire div_exe_cnt_inc = exec_cnt_inc & i_op_div;
wire corrct_phase = muldiv_sta_is_remd_corr | muldiv_sta_is_quot_corr;
wire check_phase = muldiv_sta_is_remd_chck;
wire [33:0] div_quot_corr_alu_res;
wire [33:0] div_remd_corr_alu_res;
// Note: in last cycle, the reminder value is the non-shifted value
// but the quotient value is the shifted value, and last bit of quotient value is shifted always by 1
// If need corrective, the correct quot first, and then reminder, so reminder output as comb logic directly to
// save a cycle
wire [32:0] div_remd = check_phase ? part_remd_r [32:0]:
corrct_phase ? div_remd_corr_alu_res[32:0] :
div_exe_part_remd[65:33];
wire [32:0] div_quot = check_phase ? part_quot_r [32:0]:
corrct_phase ? part_quot_r [32:0]:
{div_exe_part_remd[31:0],1’b1};
// The partial reminder and quotient
wire [32:0] part_remd_nxt = corrct_phase ? div_remd_corr_alu_res[32:0] :
(muldiv_sta_is_exec & div_exec_last_cycle) ? div_remd :
div_exe_part_remd_lsft1[65:33];
wire [32:0] part_quot_nxt = corrct_phase ? div_quot_corr_alu_res[32:0] :
(muldiv_sta_is_exec & div_exec_last_cycle) ? div_quot :
div_exe_part_remd_lsft1[32: 0];
//判定是否需要进行商和余数的矫正,此判定需要用到加法器,将操作数发送给共享的数据通路
wire [33:0] div_remd_chck_alu_res = muldiv_req_alu_res[33:0];
wire [33:0] div_remd_chck_alu_op1 = {part_remd_r[32], part_remd_r};
wire [33:0] div_remd_chck_alu_op2 = divisor;
wire div_remd_chck_alu_add = 1’b1;
wire div_remd_chck_alu_sub = 1’b0;
wire remd_is_0 = ~(|part_remd_r);
wire remd_is_neg_divs = ~(|div_remd_chck_alu_res);
wire remd_is_divs = (part_remd_r == divisor[32:0]);
assign div_need_corrct = i_op_div & (
((part_remd_r[32] ^ dividend[65]) & (~remd_is_0))
| remd_is_neg_divs
| remd_is_divs
wire remd_inc_quot_dec = (part_remd_r[32] ^ divisor[33]);
//进行商的矫正所需的加法运算,将操作数和操作类型发送给共享的数据通路
assign div_quot_corr_alu_res = muldiv_req_alu_res[33:0];
wire [33:0] div_quot_corr_alu_op1 = {part_quot_r[32], part_quot_r};
wire [33:0] div_quot_corr_alu_op2 = 34’b1;
wire div_quot_corr_alu_add = (~remd_inc_quot_dec);
wire div_quot_corr_alu_sub = remd_inc_quot_dec;
//进行余数的矫正所需的加法运算,将操作数和操作类型发送给共享的数据通路
assign div_remd_corr_alu_res = muldiv_req_alu_res[33:0];
wire [33:0] div_remd_corr_alu_op1 = {part_remd_r[32], part_remd_r};
wire [33:0] div_remd_corr_alu_op2 = divisor;
wire div_remd_corr_alu_add = remd_inc_quot_dec;
wire div_remd_corr_alu_sub = ~remd_inc_quot_dec;
// The partial reminder register will be loaded in the exe state, and in reminder correction cycle
assign part_remd_ena = div_exe_cnt_set | div_exe_cnt_inc | state_exec_exit_ena | state_remd_corr_exit_ena;
// The partial quotient register will be loaded in the exe state, and in quotient correction cycle
wire part_quot_ena = div_exe_cnt_set | div_exe_cnt_inc | state_exec_exit_ena | state_quot_corr_exit_ena;
wire[E203_XLEN-1:0] div_res = (i_div | i_divu) ? div_quot[E203_XLEN-1:0] : div_remd[`E203_XLEN-1:0];
wire div_by_0 = ~(|muldiv_i_rs2);// Divisor is all zeros
wire div_ovf = (i_div | i_rem) & (&muldiv_i_rs2) // Divisor is all ones, means -1
//Dividend is 10000…000, means -(2^xlen -1)
& muldiv_i_rs1[E203_XLEN-1] & (~(|muldiv_i_rs1[E203_XLEN-2:0]));
wire[E203_XLEN-1:0] div_by_0_res_quot = ~E203_XLEN’b0;
wire[E203_XLEN-1:0] div_by_0_res_remd = dividend[E203_XLEN-1:0];
wire[`E203_XLEN-1:0] div_by_0_res = (i_div | i_divu) ? div_by_0_res_quot : div_by_0_res_remd;
wire[E203_XLEN-1:0] div_ovf_res_quot = {1'b1,{E203_XLEN-1{1’b0}}};
wire[E203_XLEN-1:0] div_ovf_res_remd =E203_XLEN’b0;
wire[`E203_XLEN-1:0] div_ovf_res = (i_div | i_divu) ? div_ovf_res_quot : div_ovf_res_remd;
wire div_special_cases = i_op_div & (div_by_0 | div_ovf);
wire[`E203_XLEN-1:0] div_special_res = div_by_0 ? div_by_0_res : div_ovf_res;
// Output generateion
assign special_cases = div_special_cases;// Only divider have special cases
wire[`E203_XLEN-1:0] special_res = div_special_res;// Only divider have special cases
// To detect the sequence of MULH[[S]U] rdh, rs1, rs2; MUL rdl, rs1, rs2
// To detect the sequence of DIV[U] rdq, rs1, rs2; REM[U] rdr, rs1, rs2
wire [E203_XLEN-1:0] back2back_mul_res = {part_prdt_lo_r[E203_XLEN-2:0],part_prdt_sft1_r};// Only the MUL will be treated as back2back
wire [E203_XLEN-1:0] back2back_mul_rem = part_remd_r[E203_XLEN-1:0];
wire [E203_XLEN-1:0] back2back_mul_div = part_quot_r[E203_XLEN-1:0];
wire [E203_XLEN-1:0] back2back_res = ( ({E203_XLEN{i_mul }} & back2back_mul_res)
| ({E203_XLEN{i_rem | i_remu}} & back2back_mul_rem) | ({E203_XLEN{i_div | i_divu}} & back2back_mul_div)
// The output will be valid:
//   * If it is back2back and sepcial cases, just directly pass out from input
//   * If it is not back2back sequence when it is the last cycle of exec state
//     (not div need correction) or last correct state;
wire wbck_condi = (back2back_seq | special_cases) ? 1’b1 :
(muldiv_sta_is_exec & exec_last_cycle & (~i_op_div))
| (muldiv_sta_is_remd_chck & (~div_need_corrct))
assign muldiv_o_valid = wbck_condi & muldiv_i_valid;
assign muldiv_i_ready = wbck_condi & muldiv_o_ready;
wire res_sel_spl = special_cases;
wire res_sel_b2b = back2back_seq & (~special_cases);
wire res_sel_div = (~back2back_seq) & (~special_cases) & i_op_div;
wire res_sel_mul = (~back2back_seq) & (~special_cases) & i_op_mul;
assign muldiv_o_wbck_wdat =
({E203_XLEN{res_sel_b2b}} & back2back_res) | ({E203_XLEN{res_sel_spl}} & special_res)
| ({E203_XLEN{res_sel_div}} & div_res) | ({E203_XLEN{res_sel_mul}} & mul_res);
assign muldiv_o_wbck_err = 1’b0;
wire req_alu_sel1 = i_op_mul;
wire req_alu_sel2 = i_op_div & (muldiv_sta_is_0th | muldiv_sta_is_exec);
wire req_alu_sel3 = i_op_div & muldiv_sta_is_quot_corr;
wire req_alu_sel4 = i_op_div & muldiv_sta_is_remd_corr;
wire req_alu_sel5 = i_op_div & muldiv_sta_is_remd_chck;
//为了与ALU的其他子单元共享运算数据通路,将运算所需要的操作数发送给运算数据通路进行运算
//操作数1
assign muldiv_req_alu_op1 =
({E203_MULDIV_ADDER_WIDTH{req_alu_sel1}} & mul_exe_alu_op1 ) | ({E203_MULDIV_ADDER_WIDTH{req_alu_sel2}} & {{E203_MULDIV_ADDER_WIDTH-34{1'b0}},div_exe_alu_op1 }) | ({E203_MULDIV_ADDER_WIDTH{req_alu_sel3}} & {{E203_MULDIV_ADDER_WIDTH-34{1'b0}},div_quot_corr_alu_op1}) | ({E203_MULDIV_ADDER_WIDTH{req_alu_sel4}} & {{E203_MULDIV_ADDER_WIDTH-34{1'b0}},div_remd_corr_alu_op1}) | ({E203_MULDIV_ADDER_WIDTH{req_alu_sel5}} & {{E203_MULDIV_ADDER_WIDTH-34{1'b0}},div_remd_chck_alu_op1}); //操作数2 assign muldiv_req_alu_op2 = ({E203_MULDIV_ADDER_WIDTH{req_alu_sel1}} & mul_exe_alu_op2 )
| ({E203_MULDIV_ADDER_WIDTH{req_alu_sel2}} & {{E203_MULDIV_ADDER_WIDTH-34{1’b0}},div_exe_alu_op2 })
| ({E203_MULDIV_ADDER_WIDTH{req_alu_sel3}} & {{E203_MULDIV_ADDER_WIDTH-34{1’b0}},div_quot_corr_alu_op2})
| ({E203_MULDIV_ADDER_WIDTH{req_alu_sel4}} & {{E203_MULDIV_ADDER_WIDTH-34{1’b0}},div_remd_corr_alu_op2})
| ({E203_MULDIV_ADDER_WIDTH{req_alu_sel5}} & {{E203_MULDIV_ADDER_WIDTH-34{1’b0}},div_remd_chck_alu_op2});
//操作数3
assign muldiv_req_alu_op3 = {`E203_MULDIV_ADDER_WIDTH{req_alu_sel1}} & mul_exe_alu_op3;
//指令需要进行加法操作
assign muldiv_req_alu_add =
(req_alu_sel1 & mul_exe_alu_add )
| (req_alu_sel2 & div_exe_alu_add )
| (req_alu_sel3 & div_quot_corr_alu_add)
| (req_alu_sel4 & div_remd_corr_alu_add)
| (req_alu_sel5 & div_remd_chck_alu_add);
//指令需要进行减法操作
assign muldiv_req_alu_sub =
(req_alu_sel1 & mul_exe_alu_sub )
| (req_alu_sel2 & div_exe_alu_sub )
| (req_alu_sel3 & div_quot_corr_alu_sub)
| (req_alu_sel4 & div_remd_corr_alu_sub)
| (req_alu_sel5 & div_remd_chck_alu_sub);
//为了与AGU单元共享运算数据通路,将需要存储的部分积或者部分余数发送给运算数据通路进行寄存
assign muldiv_sbf_0_ena = part_remd_ena | part_prdt_hi_ena;
assign muldiv_sbf_0_nxt = i_op_mul ? part_prdt_hi_nxt : part_remd_nxt;
assign muldiv_sbf_1_ena = part_quot_ena | part_prdt_lo_ena;
assign muldiv_sbf_1_nxt = i_op_mul ? part_prdt_lo_nxt : part_quot_nxt;
assign part_remd_r = muldiv_sbf_0_r;
assign part_quot_r = muldiv_sbf_1_r;
assign part_prdt_hi_r = muldiv_sbf_0_r;
assign part_prdt_lo_r = muldiv_sbf_1_r;
assign muldiv_i_longpipe = 1’b0;
ifndef FPGA_SOURCE//{ifndef DISABLE_SV_ASSERTION//{
//synopsys translate_off
// These below code are used for reference check with assertion
wire [31:0] golden0_mul_op1 = mul_op1[32] ? (~mul_op1[31:0]+1) : mul_op1[31:0];
wire [31:0] golden0_mul_op2 = mul_op2[32] ? (~mul_op2[31:0]+1) : mul_op2[31:0];
wire [63:0] golden0_mul_res_pre = golden0_mul_op1 golden0_mul_op2;
wire [63:0] golden0_mul_res = (mul_op1[32]^mul_op2[32]) ? (~golden0_mul_res_pre + 1) : golden0_mul_res_pre;
wire [63:0] golden1_mul_res = $signed(mul_op1)
$signed(mul_op2);
// To check the signed * operation is really get what we wanted
CHECK_SIGNED_OP_CORRECT:
assert property (@(posedge clk) disable iff ((~rst_n) | (~muldiv_o_valid)) ((golden0_mul_res == golden1_mul_res)))
else $fatal (“\n Error: Oops, This should never happen. \n”);
wire [31:0] golden1_res_mul = golden1_mul_res[31:0];
wire [31:0] golden1_res_mulh = golden1_mul_res[63:32];
wire [31:0] golden1_res_mulhsu = golden1_mul_res[63:32];
wire [31:0] golden1_res_mulhu = golden1_mul_res[63:32];
wire [63:0] golden2_res_mul_SxS = $signed(muldiv_i_rs1) $signed(muldiv_i_rs2);
wire [63:0] golden2_res_mul_SxU = $signed(muldiv_i_rs1)
$unsigned(muldiv_i_rs2);
wire [63:0] golden2_res_mul_UxS = $unsigned(muldiv_i_rs1) $signed(muldiv_i_rs2);
wire [63:0] golden2_res_mul_UxU = $unsigned(muldiv_i_rs1)
wire [31:0] golden2_res_mul = golden2_res_mul_SxS[31:0];
wire [31:0] golden2_res_mulh = golden2_res_mul_SxS[63:32];
wire [31:0] golden2_res_mulhsu = golden2_res_mul_SxU[63:32];
wire [31:0] golden2_res_mulhu = golden2_res_mul_UxU[63:32];
// To check four different combination will all generate same lower 32bits result
CHECK_FOUR_COMB_SAME_RES:
(golden2_res_mul_SxS[31:0] == golden2_res_mul_SxU[31:0])
& (golden2_res_mul_UxS[31:0] == golden2_res_mul_UxU[31:0])
& (golden2_res_mul_SxU[31:0] == golden2_res_mul_UxS[31:0])
  // Seems the golden2 result is not correct in case of mulhsu, so have to comment it out
// // To check golden1 and golden2 result are same
// CHECK_GOLD1_AND_GOLD2_SAME:
// assert property (@(posedge clk) disable iff ((~rst_n) | (~muldiv_o_valid))
// (i_mul ? (golden1_res_mul == golden2_res_mul ) : 1’b1)
// &(i_mulh ? (golden1_res_mulh == golden2_res_mulh ) : 1’b1)
// &(i_mulhsu ? (golden1_res_mulhsu == golden2_res_mulhsu) : 1’b1)
// &(i_mulhu ? (golden1_res_mulhu == golden2_res_mulhu ) : 1’b1)
// else $fatal (“\n Error: Oops, This should never happen. \n”);
 // The special case will need to be handled specially
wire [32:0] golden_res_div = div_special_cases ? div_special_res :
( $signed({div_rs1_sign,muldiv_i_rs1}) / ((div_by_0 | div_ovf) ? 1 : $signed({div_rs2_sign,muldiv_i_rs2})));
wire [32:0] golden_res_divu = div_special_cases ? div_special_res :
($unsigned({div_rs1_sign,muldiv_i_rs1}) / ((div_by_0 | div_ovf) ? 1 : $unsigned({div_rs2_sign,muldiv_i_rs2})));
wire [32:0] golden_res_rem = div_special_cases ? div_special_res :
( $signed({div_rs1_sign,muldiv_i_rs1}) % ((div_by_0 | div_ovf) ? 1 : $signed({div_rs2_sign,muldiv_i_rs2})));
wire [32:0] golden_res_remu = div_special_cases ? div_special_res :
($unsigned({div_rs1_sign,muldiv_i_rs1}) % ((div_by_0 | div_ovf) ? 1 : $unsigned({div_rs2_sign,muldiv_i_rs2})));
// To check golden and actual result are same
wire [E203_XLEN-1:0] golden_res = i_mul ? golden1_res_mul : i_mulh ? golden1_res_mulh : i_mulhsu ? golden1_res_mulhsu : i_mulhu ? golden1_res_mulhu : i_div ? golden_res_div [31:0] : i_divu ? golden_res_divu[31:0] : i_rem ? golden_res_rem [31:0] : i_remu ? golden_res_remu[31:0] :E203_XLEN’b0;
CHECK_GOLD_AND_ACTUAL_SAME:
// Since the printed value is not aligned with posedge clock, so change it to negetive
assert property (@(negedge clk) disable iff ((~rst_n) | flush_pulse)
(muldiv_o_valid ? (golden_res == muldiv_o_wbck_wdat ) : 1’b1)
else begin
$display(“??????????????????????????????????????????”);
$display(“{i_mul,i_mulh,i_mulhsu,i_mulhu,i_div,i_divu,i_rem,i_remu}=%d%d%d%d%d%d%d%d”,i_mul,i_mulh,i_mulhsu,i_mulhu,i_div,i_divu,i_rem,i_remu);
$display(“muldiv_i_rs1=%h\nmuldiv_i_rs2=%h\n”,muldiv_i_rs1,muldiv_i_rs2);
$display(“golden_res=%h\nmuldiv_o_wbck_wdat=%h”,golden_res,muldiv_o_wbck_wdat);
//synopsys translate_on
endif//}endif//}
endmodule
`endif//}
