【求助贴】run_openocd报错
开发板:达芬奇pro 35T
调试器:SIPEED RV-Debugger plus
run_openocd报错如下:
- Start openocd server
- openocd -c “gdb_port 3333” -f ../../../SoC/hbirdv2/Board/ddr200t/openocd_hbirdv2.cfg
- Nuclei OpenOCD, 64-bit Open On-Chip Debugger 0.10.0+dev-00036-gbfc178ffb (2021-02-01-06:41)
- Licensed under GNU GPL v2
- For bug reports, read
- http://openocd.org/doc/doxygen/bugs.html
- Info : Using libusb driver
- Info : clock speed 1000 kHz
- Info : JTAG tap: riscv.cpu tap/device found: 0x200a6d01 (mfg: 0x680 (
), part: 0x00a6, ver: 0x2) - Info : TAP auto0.tap does not have IDCODE
- Info : JTAG tap: auto1.tap tap/device found: 0xffffff8f (mfg: 0x7c7 (
), part: 0xffff, ver: 0xf) - Warn : AUTO auto0.tap - use “jtag newtap auto0 tap -irlen 2 -expected-id 0x00000000”
- Error: auto0.tap: IR capture error; saw 0x0000 not 0x0001
- Warn : Bypassing JTAG setup events due to errors
- Info : Exposing additional CSR 770
- Info : Exposing additional CSR 771
- Info : Exposing additional CSR 775
- Info : Exposing additional CSR 776
- Info : Exposing additional CSR 777
- Info : Exposing additional CSR 778
- Info : Exposing additional CSR 779
- Info : Exposing additional CSR 780
- Info : Exposing additional CSR 781
- Info : Exposing additional CSR 782
- Info : Exposing additional CSR 783
- Info : Exposing additional CSR 784
- Info : Exposing additional CSR 785
- Info : Exposing additional CSR 786
- Info : Exposing additional CSR 787
- Info : Exposing additional CSR 788
- Info : Exposing additional CSR 789
- Info : Exposing additional CSR 790
- Info : Exposing additional CSR 791
- Info : Exposing additional CSR 792
- Info : Exposing additional CSR 793
- Info : Exposing additional CSR 794
- Info : Exposing additional CSR 795
- Info : Exposing additional CSR 796
- Info : Exposing additional CSR 797
- Info : Exposing additional CSR 798
- Info : Exposing additional CSR 799
- Info : Exposing additional CSR 800
- Info : Exposing additional CSR 837
- Info : Exposing additional CSR 838
- Info : Exposing additional CSR 839
- Info : Exposing additional CSR 840
- Info : Exposing additional CSR 841
- Info : Exposing additional CSR 842
- Info : Exposing additional CSR 843
- Info : Exposing additional CSR 844
- Info : Exposing additional CSR 845
- Info : Exposing additional CSR 846
- Info : Exposing additional CSR 847
- Info : Exposing additional CSR 848
- Info : Exposing additional CSR 849
- Info : Exposing additional CSR 850
- Info : Exposing additional CSR 1984
- Info : Exposing additional CSR 1985
- Info : Exposing additional CSR 1986
- Info : Exposing additional CSR 1987
- Info : Exposing additional CSR 1988
- Info : Exposing additional CSR 1989
- Info : Exposing additional CSR 1990
- Info : Exposing additional CSR 1991
- Info : Exposing additional CSR 1992
- Info : Exposing additional CSR 1993
- Info : Exposing additional CSR 1994
- Info : Exposing additional CSR 1995
- Info : Exposing additional CSR 1996
- Info : Exposing additional CSR 1997
- Info : Exposing additional CSR 1998
- Info : Exposing additional CSR 1999
- Info : Exposing additional CSR 2000
- Info : Exposing additional CSR 2001
- Info : Exposing additional CSR 2002
- Info : Exposing additional CSR 2003
- Info : Exposing additional CSR 2004
- Info : Exposing additional CSR 2005
- Info : Exposing additional CSR 2006
- Info : Exposing additional CSR 2007
- Info : Exposing additional CSR 2008
- Info : Exposing additional CSR 2009
- Info : Exposing additional CSR 2010
- Info : Exposing additional CSR 2011
- Info : Exposing additional CSR 2012
- Info : Exposing additional CSR 2013
- Info : Exposing additional CSR 2014
- Info : Exposing additional CSR 2015
- Info : Exposing additional CSR 2016
- Info : Exposing additional CSR 2017
- Info : Exposing additional CSR 2018
- Info : Exposing additional CSR 2019
- Info : Exposing additional CSR 2020
- Info : Exposing additional CSR 2021
- Info : Exposing additional CSR 2022
- Info : Exposing additional CSR 2023
- Info : Exposing additional CSR 2024
- Info : Exposing additional CSR 2025
- Info : Exposing additional CSR 2026
- Info : Exposing additional CSR 2027
- Info : Exposing additional CSR 2028
- Info : Exposing additional CSR 2029
- Info : Exposing additional CSR 2030
- Info : Exposing additional CSR 2031
- Info : Exposing additional CSR 2032
- Info : Exposing additional CSR 2064
- Info : Exposing additional CSR 2065
- Info : Exposing additional CSR 2066
- Info : Exposing additional CSR 2067
- Info : Exposing additional CSR 2068
- Info : Exposing additional CSR 2069
- Info : Exposing additional CSR 2070
- Error: dtmcontrol is 0. Check JTAG connectivity/board power.
- Info : Listening on port 3333 for gdb connections
make: * [../../../Build/Makefile.rules:107:run_openocd] 错误 1
回复1
浏览5913
发布2024-04-29 21:55
