论坛/开源蜂鸟E203/【求助】E203移植黑金AX7020开发板无法烧录HelloWorld程序
开源蜂鸟E203 作者 高嵩登 发布于 2024-07-17 18:23(855 天前) 10086 浏览
问题
在将E203内核下载进FPGA开发板后,使用Nuclei Studio烧录Hello World时OpenOCD报错
已经尝试过的方案
1.检查JTAG连接与约束,无误
2.将顶层中TDO从inout改成output,无效
3.重新安装驱动,无效
4.更换USB口,无效
硬件连接状况照片
硬件配置及软件版本
开发板:黑金AX7020(xc7z020clg400-2)
下载器:蜂鸟Debugger Kit V2
IDE版本:NucleiStudio 2022.04
Nuclei项目配置
Run Configuration
openocd_hbirdv2.cfg
cfg文件内注释掉了flash相关的三行代码
adapter_khz     1000
interface ftdi
ftdi_vid_pid 0x0403 0x6010
ftdi_oscan1_mode off
transport select jtag
ftdi_layout_init 0x0008 0x001b
ftdi_layout_signal nSRST -oe 0x0020 -data 0x0020
ftdi_layout_signal TCK -data 0x0001
ftdi_layout_signal TDI -data 0x0002
ftdi_layout_signal TDO -input 0x0004
ftdi_layout_signal TMS -data 0x0008
ftdi_layout_signal JTAG_SEL -data 0x0100 -oe 0x0100
set _CHIPNAME riscv
jtag newtap $_CHIPNAME cpu -irlen 5
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME riscv -chain-position $_TARGETNAME
$_TARGETNAME configure -work-area-phys 0x80000000 -work-area-size 10000 -work-area-backup 1
# set _FLASHNAME $_CHIPNAME.flash
# flash bank $_FLASHNAME fespi 0x20000000 0 0 0 $_TARGETNAME
# Set the ILM space also as flash, to make sure it can be add breakpoint with hardware trigger
#flash bank onboard_ilm fespi 0x80000000 0 0 0 $_TARGETNAME
# Expose Nuclei self-defined CSRS range 770-800,835-850,1984-2032,2064-2070
# See https://github.com/riscv/riscv-gnu-toolchain/issues/319#issuecomment-358397306
# Then user can view the csr register value in gdb using: info reg csr775 for CSR MTVT(0x307)
riscv expose_csrs 770-800,835-850,1984-2032,2064-2070
init
#reset
if {[ info exists pulse_srst]} {
  ftdi_set_signal nSRST 0
  ftdi_set_signal nSRST z
halt
# We must turn on this because otherwise the IDE version debug cannot download the program into flash
# flash protect 0 0 last off
OpenOCD输出
Open On-Chip Debugger 0.11.0+dev-01897-gc8fc2a168 (2022-04-01-04:46)
Licensed under GNU GPL v2
For bug reports, read
DEPRECATED! use 'adapter speed' not 'adapter_khz'
DEPRECATED! use 'adapter driver' not 'interface'
Info : Using libusb driver
Info : clock speed 1000 kHz
Error: JTAG scan chain interrogation failed: all ones
Error: Check JTAG interface, timings, target power, etc.
Error: Trying to use configured scan chain anyway...
Error: riscv.cpu: IR capture error; saw 0x1f not 0x01
Error: Unsupported DTM version: 15
驱动安装情况
按照 https://www.rvmcu.com/community-topic-id-464.html 安装了驱动
约束文件
顶层文件中将TDO从inout改成了output
#=========================== Sys Clock & rstn ================================
## Clock Signal     50M
set_property -dict { PACKAGE_PIN U18    IOSTANDARD LVCMOS33 } [get_ports { clk }]; #U18
create_clock -add -name sys_clk_pin -period 20.00 -waveform {0 10} [get_ports clk]
## mcu Rst_n
set_property -dict { PACKAGE_PIN N15  IOSTANDARD LVCMOS33 } [get_ports { mcu_rst }]; #PL_KEY1   N15
set_property -dict { PACKAGE_PIN M14  IOSTANDARD LVCMOS33 }  [get_ports {rst_led }]; #PL LED1
#=========================== Debug JTAG ======================================
set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets IOBUF_jtag_TCK/O]
set_property CLOCK_DEDICATED_ROUTE FALSE [get_nets dut_io_pads_jtag_TCK_i_ival]
# mcu_TCK
# mcu_TDO
# mcu_TMS
# rst
# mcu_TDI
# JTAG Debug Port
set_property -dict { PACKAGE_PIN W15  IOSTANDARD LVCMOS33 } [get_ports { mcu_TCK }]; #J10-9
set_property -dict { PACKAGE_PIN V15  IOSTANDARD LVCMOS33 } [get_ports { mcu_TDO }]; #J10-10
set_property -dict { PACKAGE_PIN Y14  IOSTANDARD LVCMOS33 } [get_ports { mcu_TMS }]; #J10-11
set_property -dict { PACKAGE_PIN W14  IOSTANDARD LVCMOS33 } [get_ports { mcu_TDI }]; #J10-12
#------------------------ End of Debug JTAG ----------------------------------
#=============================== UART 0 ======================================
set_property -dict { PACKAGE_PIN P18   IOSTANDARD LVCMOS33 } [get_ports { uart0_tx }]; #J10-13
set_property -dict { PACKAGE_PIN N17   IOSTANDARD LVCMOS33 } [get_ports { uart0_rx }]; #J10-14
#---------------------------- End of UART 0 --------------------------------
#LED1
#LED2
#LED3
#LED4
#PL_KEY1
#PL_KEY2
## GPIOA
#LEDs
# set_property -dict { PACKAGE_PIN M14   IOSTANDARD LVCMOS33 } [get_ports { gpioA_0 }]; # M14
set_property -dict { PACKAGE_PIN M15   IOSTANDARD LVCMOS33 } [get_ports { gpioA_1 }]; # M15
set_property -dict { PACKAGE_PIN K16   IOSTANDARD LVCMOS33 } [get_ports { gpioA_2 }]; # K16
set_property -dict { PACKAGE_PIN J16   IOSTANDARD LVCMOS33 } [get_ports { gpioA_3 }]; # J16
#KEY
set_property -dict { PACKAGE_PIN N16   IOSTANDARD LVCMOS33 } [get_ports { gpioA_4 }]; # N16 PL_KEY2
# USERIO
set_property -dict { PACKAGE_PIN F17   IOSTANDARD LVCMOS33 } [get_ports { gpioA_5 }]; # J11-3
set_property -dict { PACKAGE_PIN F16   IOSTANDARD LVCMOS33 } [get_ports { gpioA_6 }]; # J11-4
set_property -dict { PACKAGE_PIN F20   IOSTANDARD LVCMOS33 } [get_ports { gpioA_7 }]; # J11-5
set_property KEEPER true [get_ports mcu_TMS]
全部回复 11
你
你好生活397 天前 · 1 楼
回复 jiamingd:
可以加我q帮你看看, 2864683603
请问可以帮我看一下吗,我也是有这个问题,可以的话我加你qq
j
jiamingd442 天前 · 2 楼
回复 GZ.:
你好你好,我也遇到了这个问题请问解决了吗,可以分享一下解决方法吗
j
jiamingd442 天前 · 3 楼
看报错信息显示,tdo一直为1。可以尝试用ila抓一下jtag信号的波形,看TAP是否收到了tms tck tdi等信号
y
yuuki455 天前 · 4 楼
回复 GZ.:
没有,最后还是用了芯来官方的nuclei ddr200t开发版,怀疑是jtag调试器的问题
GZ.
GZ.455 天前 · 5 楼
回复 yuuki:
一样的问题,请问解决了吗?
y
yuuki624 天前 · 6 楼
回复 三木力:
Open On-Chip Debugger 0.11.0+dev-01875-g13d7bc6cf (2021-09-25-22:27)
Info : D2xx device count: 2
Info : Connecting to "(null)" using D2xx mode...
楼主一样的报错,最后解决掉了吗
一样的问题,请问解决了吗?
y
yuuki624 天前 · 7 楼
一样的问题,请问楼主解决了吗?
三
三木力724 天前 · 8 楼
楼主一样的报错,最后解决掉了吗
小
小白two850 天前 · 9 楼
回复 高嵩登:
OpenOCD输出哪个就是报错信息
调试器没连上吧
高
高嵩登853 天前 · 10 楼
回复 小白two:
报错信息粘一下
OpenOCD输出哪个就是报错信息
小
小白two853 天前 · 11 楼
报错信息粘一下
