CM32M433R-START上关于一些例程的问题
#include "main.h"
#include
#include "bsp.h"
/** @addtogroup CM32M4xxR_StdPeriph_Examples
#define MACHINE_MODE_STACK_SIZE 0x400
static uint8_t sMachineModeStack[MACHINE_MODE_STACK_SIZE] = {0};
//Configure test_array Acess Permission on PMP
void PMP_Config() {
PMP_Region_InitTypeDef pmp_init;
pmp_init.Number = PMP_REGION_NUMBER0;
pmp_init.Enable = PMP_REGION_ENABLE; // Enable Configuration
pmp_init.Lock = PMP_REGION_UNLOCK; //
pmp_init.BaseAddress = 0; //
pmp_init.Size = PMP_REGION_SIZE_4GB; //Setting array size
pmp_init.AddressMatching = PMP_ADDRESS_MATCHING_NAPOT; //Setting PMP Size to NAPOT mode -> 2^n
pmp_init.AccessPermission = PMP_ACCESS_RWX; //Setting array permission is Read Only
PMP_ConfigRegion(&pmp_init);
sPMP_Region_InitTypeDef spmp_init;
spmp_init.Number = SPMP_REGION_NUMBER0;
spmp_init.Enable = SPMP_REGION_ENABLE;
spmp_init.Lock = SPMP_REGION_UNLOCK;
spmp_init.BaseAddress = 0;
spmp_init.Size = SPMP_REGION_SIZE_4GB;
spmp_init.AddressMatching = SPMP_ADDRESS_MATCHING_NAPOT;
spmp_init.UserMode = SPMP_USERMODE_RESET;
spmp_init.AccessPermission = SPMP_ACCESS_RWX;
sPMP_ConfigRegion(&spmp_init);
* @brief Jump User Mode
void JumpUserMode(uint32_t func)
__RV_CSR_WRITE(CSR_MSCRATCH, sMachineModeStack + MACHINE_MODE_STACK_SIZE);
__RV_CSR_CLEAR(CSR_MSTATUS, MSTATUS_MPP);
__RV_CSR_WRITE(CSR_MEPC, func);
__ASM volatile ( "mret ");
* @brief User Mode Application
void Led()
LedInit(LED2_PORT, LED2_PIN);
while (1)
LedBlink(LED2_PORT, LED2_PIN);
delay_ms(1000);
* @brief Main function
int main(void) {
/* System Clocks Configuration */
PMP_Config();
JumpUserMode((uint32_t)Led);
while (1) {
Projects\CM32M433R-START\Examples\RISC-V\UserMode这个目录下的例程,为什么分别设置了pmp和spmp对整个区间的限制?难道只设置一个不可以?(只设置一个确实会触发异常,只设置spmp时是异常1,只设置pmp异常12且mdcause为6也就是spmp加载异常,但是,why?)这块很奇怪,暂且不说把整个指令地址空间设置保护相当于没保护,那这个例程只涉及了M和U模式为什么还要动SPMP??想问一下这块板子是不是开了虚拟页管理?我只用到PMP的话应该如何设置??
版块CM32M433R MCU
回复2
浏览4687
发布2025-01-11 17:22
本版热门
关于如何创建一个浮点立即数0 回复
