论坛/开源蜂鸟E203/make upload报错
make upload报错
开源蜂鸟E203 作者 Lynn Peng 发布于 2020-10-16 19:12(2225 天前) 7843 浏览
硬件环境为蜂鸟实验板和调试器。修改e203的代码,然后综合生成*.mcs文件,下载至开发板,然后编写软件代码下载到开发板时出现如下现象。起初下载软件程序至开发板,upload成功,screen打印出结果。但多下载几次或者断电后重新下载软件代码至开发板,出现错误,错误如下:
Info : Exposing additional CSR 3067
Info : Exposing additional CSR 3068
Info : Exposing additional CSR 3069
Info : Exposing additional CSR 3070
Info : Exposing additional CSR 3071
Error: Timed out waiting for debug int to clear.Increase timeout with riscv set_command_timeout_sec.
Error: Debug interrupt didn't clear.
Error: Debug RAM 0x0: 0xfff04493
Error: Debug RAM 0x1: 0x01f4d493
Error: Debug RAM 0x2: 0x40902023
Error: Debug RAM 0x3: 0x01f4d493
Error: Debug RAM 0x4: 0x40902223
Error: Debug RAM 0x5: 0x3f00006f
Error: Debug RAM 0x6: 0x060c1218
Error: Debug RAM 0x7: 0x00000000
Error: Debug RAM 0x8: 0x00000000
Error: Debug RAM 0x9: 0x00000000
Error: Debug RAM 0xa: 0x00000000
Error: Debug RAM 0xb: 0x00000000
Error: Debug RAM 0xc: 0x00000000
Error: Debug RAM 0xd: 0x00000000
Error: Debug RAM 0xe: 0x00000000
Error: Debug RAM 0xf: 0x00000000
Error: Failed to discover xlen; word0=0xfff04493, word1=0x1f4d493, exception=0x60c1218
Warn : Flash driver of my_first_flash does not support free_driver_priv()
localhost:3333: Connection timed out.
"monitor" command not supported by this target.
You can't do that when your target is `exec'
领主文2162 天前 · 1 楼
不清楚你改了E203的什么部分,可能是改的有问题,可以说一下嘛?
