开源RISC-V处理器(蜂鸟E203)学习(三)低成本方案,成功运行hello word程序
1.简述
SA56W-UR34V-7KY76-XB31F-HZPAU
adapter_khz 1000
interface ftdi
ftdi_vid_pid 0x0403 0x6010
ftdi_oscan1_mode off
transport select jtag
ftdi_layout_init 0x0008 0x001b
ftdi_layout_signal nSRST -oe 0x0020 -data 0x0020
ftdi_layout_signal TCK -data 0x0001
ftdi_layout_signal TDI -data 0x0002
ftdi_layout_signal TDO -input 0x0004
ftdi_layout_signal TMS -data 0x0008
ftdi_layout_signal JTAG_SEL -data 0x0100 -oe 0x0100
set _CHIPNAME riscv
jtag newtap $_CHIPNAME cpu -irlen 5
set _TARGETNAME $_CHIPNAME.cpu
target create $_TARGETNAME riscv -chain-position $_TARGETNAME
$_TARGETNAME configure -work-area-phys 0x80000000 -work-area-size 10000 -work-area-backup 1
#set _FLASHNAME $_CHIPNAME.flash
#flash bank $_FLASHNAME fespi 0x20000000 0 0 0 $_TARGETNAME
# Set the ILM space also as flash, to make sure it can be add breakpoint with hardware trigger
#flash bank onboard_ilm fespi 0x80000000 0 0 0 $_TARGETNAME
# Expose Nuclei self-defined CSRS range 770-800,835-850,1984-2032,2064-2070
# See https://github.com/riscv/riscv-gnu-toolchain/issues/319#issuecomment-358397306
# Then user can view the csr register value in gdb using: info reg csr775 for CSR MTVT(0x307)
riscv expose_csrs 770-800,835-850,1984-2032,2064-2070
init
#reset
if {[ info exists pulse_srst]} {
ftdi_set_signal nSRST 0
ftdi_set_signal nSRST z
halt
# We must turn on this because otherwise the IDE version debug cannot download the program into flash
#flash protect 0 0 last off
回复1
浏览9262
发布2021-04-18 13:20
