蜂鸟E203与电脑实现UART通信实现代码并实现上位机控制代码分享
大家好,我们是这是一件好事队,队伍编号为CICC1859,这里想和大家分享一下蜂鸟E203与电脑的UART通信代码,并通过UART实现上位机控制。
电脑端UART代码:
#include "stdio.h"
HANDLE GetSerialPortHandle(const char *name) {
printf("Opening %s...\n", name);
fflush(stdout);
HANDLE hCom = CreateFileA(name,
GENERIC_READ | GENERIC_WRITE,
0,
NULL,
OPEN_EXISTING,
FILE_ATTRIBUTE_NORMAL,
NULL);
if (hCom == INVALID_HANDLE_VALUE) {
printf("Open COM failed!\n");
fflush(stdout);
return NULL;
printf("Configuring Timeout...\n");
fflush(stdout);
COMMTIMEOUTS TimeOuts;
TimeOuts.ReadIntervalTimeout = 0;
TimeOuts.ReadTotalTimeoutMultiplier = 0;
TimeOuts.ReadTotalTimeoutConstant = 0;
TimeOuts.WriteTotalTimeoutMultiplier = 1;
TimeOuts.WriteTotalTimeoutConstant = 1;
SetCommTimeouts(hCom, &TimeOuts);
printf("Configuring serial port...\n");
fflush(stdout);
DCB dcb;
GetCommState(hCom, &dcb);
dcb.BaudRate = 115200;
dcb.ByteSize = 8;
dcb.Parity = NOPARITY;
dcb.StopBits = ONESTOPBIT;
SetCommState(hCom, &dcb);
return hCom;
void CloseSerialPortHandle(HANDLE handle) {
CloseHandle(handle);
int32_t ReadSerialPort(HANDLE hCom, uint8_t *pMessage, size_t length) {
WINBOOL bReadStat;
DWORD wCount;
bReadStat = ReadFile(hCom, pMessage, length, &wCount, NULL);
if (!bReadStat)
printf("Failed to read serial port\n");
fflush(stdout);
return bReadStat;
int32_t WriteSerialPort(HANDLE hCom, const uint8_t *pMessage, size_t length) {
WINBOOL bReadStat;
DWORD wCount;
bReadStat = WriteFile(hCom, pMessage, length, &wCount, NULL);
if (!bReadStat)
fflush(stdout);
return bReadStat;
代码主要包含开启UART:GetSerialPortHandle(),关闭UART:CloseSerialPortHandle()以及UART读写WriteSerialPort()ReadSerialPort()
蜂鸟E203 UART配置采用官方代码:
int32_t uart_init(UART_TypeDef *uart, uint32_t baudrate)
if (__RARELY(uart == NULL)) {
return -1;
unsigned int uart_div = SystemCoreClock / baudrate - 1;
uart->LCR = 0x80;
uart->DLM = (uart_div >> 8) & 0xFF;
uart->DLL = uart_div & 0xFF;
uart->FCR = 0xC6;
uart->LCR = 0x03;
return 0;
int32_t uart_config_stopbit(UART_TypeDef *uart, UART_STOP_BIT stopbit)
return -1;
uart->LCR &= 0xFFFFFFFB;
uart->LCR |= (stopbit << 2);
return 0;
int32_t uart_enable_paritybit(UART_TypeDef *uart)
return -1;
uart->LCR |= 0x8;
return 0;
int32_t uart_disable_paritybit(UART_TypeDef *uart)
return -1;
uart->LCR &= 0xFFFFFFF7;
return 0;
int32_t uart_set_parity(UART_TypeDef *uart, UART_PARITY_BIT paritybit)
return -1;
uart->LCR &= 0xFFFFFFCF;
uart->LCR |= (paritybit << 4);
return 0;
int32_t uart_write(UART_TypeDef *uart, uint8_t val)
return -1;
#ifndef SIMULATION_SPIKE
#ifndef SIMULATION_XLSPIKE
while ((uart->LSR & 0x20) == 0);
#endif
uart->THR = val;
#else
extern void htif_putc(char ch);
htif_putc(val);
#endif
return 0;
uint8_t uart_read(UART_TypeDef *uart)
uint32_t reg;
return -1;
while ((uart->LSR & 0x1) == 0);
reg = uart->RBR;
return (uint8_t)(reg & 0xFF);
int32_t uart_enable_tx_empt_int(UART_TypeDef *uart)
return -1;
uart->IER |= 0x2;
return 0;
int32_t uart_disable_tx_empt_int(UART_TypeDef *uart)
return -1;
uart->IER &= 0xFFFFFFFD;
return 0;
int32_t uart_set_rx_th(UART_TypeDef *uart, uint8_t th)
return -1;
if(th > 3) {
th = 3;
uart->FCR &= 0xFFFFFF3F;
uart->FCR |= (th << 6);
return 0;
int32_t uart_enable_rx_th_int(UART_TypeDef *uart)
return -1;
uart->IER |= 0x1;
return 0;
int32_t uart_disable_rx_th_int(UART_TypeDef *uart)
return -1;
uart->IER &= 0xFFFFFFFE;
return 0;
int32_t uart_enable_rx_err_int(UART_TypeDef *uart)
return -1;
uart->IER |= 0x4;
return 0;
int32_t uart_disable_rx_err_int(UART_TypeDef *uart)
return -1;
uart->IER &= 0xFFFFFFFB;
return 0;
int32_t uart_get_int_status(UART_TypeDef *uart)
return -1;
return uart->IIR;
int32_t uart_get_status(UART_TypeDef *uart)
return -1;
return uart->LSR;
由此配置双方UART,并在双方主函数中调用写入读取函数即可完成电脑与蜂鸟E203的通信。下面为实测图:
双方通过UART完成了Kyber(本作品设计)的通信过程。
浏览7286
发布2021-07-25 22:16
