论坛/开源蜂鸟E203/请问大家有谁用过sirv_gnrl_icb32towishb8吗
开源蜂鸟E203 作者 发布于 2021-10-22 15:06(1834 天前) 4968 浏览
从OpenCores网站下了 wb_lpc,添加进e203,寄存器读写都不行,一读就挂死了。
后来照着sirv_gnrl_icb32towishb8改了一个支持32位数据的,也一样的效果。
请过来人有空指点一二,非常感谢
在e203_subsys_perips.v中增加的内容如下:
  wire plc0_icb_cmd_valid;
  wire plc0_icb_cmd_ready;
  wire [31:0] plc0_icb_cmd_addr;
  wire plc0_icb_cmd_read;
  wire [31:0] plc0_icb_cmd_wdata;
  wire [3:0] plc0_icb_cmd_wmask;
  wire plc0_icb_rsp_valid;
  wire plc0_icb_rsp_ready;
  wire [31:0] plc0_icb_rsp_rdata;
  wire plc0_icb_rsp_err;
  wire [31:0] plc0_wishbone_addr; // lower address bits
  wire [31:0] plc0_wishbone_dat_write; // databus input
  wire [31:0] plc0_wishbone_dat_read; // databus output
  wire plc0_wishbone_write_en; // write enable input
  wire plc0_wishbone_stb; // stobe/core select signal
  wire plc0_wishbone_cyc; // valid bus cycle input
  wire plc0_wishbone_ack; // bus cycle acknowledge output
//following three signal is needed by wb_lpc_periph, not but supported by sirv_gnrl_icb32towishb
  wire [3:0] plc0_wishbone_sel;
  wire [1:0] plc0_wishbone_tga;
  wire plc0_wishbone_err;
//for LPC pins signal
  wire iopads_plc0_frame_oen;
  wire iopads_plc0_lad_output_oen;
  wire [3:0] iopads_plc0_lad_o_oen;
  wire iopads_plc0_frame;
  wire iopads_plc0_lad_output_en;
  wire [3:0] iopads_plc0_lad_i;
  wire [3:0] iopads_plc0_lad_o;
    .o15_icb_enable (1'b1),
    .o15_icb_cmd_valid (plc0_icb_cmd_valid),
    .o15_icb_cmd_ready (plc0_icb_cmd_ready),
    .o15_icb_cmd_addr (plc0_icb_cmd_addr),
    .o15_icb_cmd_read (plc0_icb_cmd_read),
    .o15_icb_cmd_wdata (plc0_icb_cmd_wdata),
    .o15_icb_cmd_wmask (plc0_icb_cmd_wmask),
    .o15_icb_cmd_lock (),
    .o15_icb_cmd_excl (),
    .o15_icb_cmd_size (),
    .o15_icb_cmd_burst (),
    .o15_icb_cmd_beat (),
    .o15_icb_rsp_valid (plc0_icb_rsp_valid),
    .o15_icb_rsp_ready (plc0_icb_rsp_ready),
    .o15_icb_rsp_err (plc0_icb_rsp_err),
    .o15_icb_rsp_excl_ok(1'b0),
    .o15_icb_rsp_rdata (plc0_icb_rsp_rdata),
sirv_gnrl_icb32towishb32 # (
  .AW (32)
) lpc0_icbtowishon_bus (
  .i_icb_cmd_valid (plc0_icb_cmd_valid),
  .i_icb_cmd_ready (plc0_icb_cmd_ready),
  .i_icb_cmd_read (plc0_icb_cmd_read),
  .i_icb_cmd_addr (plc0_icb_cmd_addr),
  .i_icb_cmd_wdata (plc0_icb_cmd_wdata),
  .i_icb_cmd_size (),
  .i_icb_rsp_valid (plc0_icb_rsp_valid),
  .i_icb_rsp_ready (plc0_icb_rsp_ready),
  .i_icb_rsp_err (plc0_icb_rsp_err),
  .i_icb_rsp_rdata (plc0_icb_rsp_rdata),
  .wb_adr (plc0_wishbone_addr), // lower address bits
  .wb_dat_w (plc0_wishbone_dat_write), // databus input
  .wb_dat_r (plc0_wishbone_dat_read), // databus output
  .wb_we (plc0_wishbone_dat_write_en), // write enable input
  .wb_stb (plc0_wishbone_dat_stb), // stobe/core select signal
  .wb_cyc (plc0_wishbone_dat_cyc), // valid bus cycle input
  .wb_ack (plc0_wishbone_dat_ack), // bus cycle acknowledge output
 .clk (clk ),
 .rst_n (bus_rst_n)
wb_lpc_periph plc0_device(
 .clk_i(clk),
 .nrst_i(bus_rst_n),
 .wbm_adr_o(plc0_wishbone_addr),
 .wbm_dat_o(plc0_wishbone_dat_write),
 .wbm_dat_i(plc0_wishbone_dat_read),
 .wbm_sel_o(plc0_wishbone_sel),
 .wbm_tga_o(plc0_wishbone_tga),
 .wbm_we_o(plc0_wishbone_dat_write_en),
 .wbm_stb_o(plc0_wishbone_dat_stb),
 .wbm_cyc_o(plc0_wishbone_dat_cyc),
 .wbm_ack_i(plc0_wishbone_dat_ack),
 .wbm_err_i(plc0_wishbone_err),
 .lframe_i(iopads_plc0_frame),
 .lad_i(iopads_plc0_lad_i),
 .lad_o(iopads_plc0_lad_o),
 .lad_oe(iopads_plc0_lad_output_en)
sirv_gnrl_icbs.v 中增加的内容:
module sirv_gnrl_icb32towishb32 # (
  parameter AW = 32
  input i_icb_cmd_valid,
  output i_icb_cmd_ready,
  input [1-1:0] i_icb_cmd_read,
  input [31:0] i_icb_cmd_addr,
  input [31:0] i_icb_cmd_wdata,
  input [1:0] i_icb_cmd_size,
  output i_icb_rsp_valid,
  input i_icb_rsp_ready,
  output i_icb_rsp_err,
  output [31:0] i_icb_rsp_rdata,
  // The 32bits wishbone slave (e.g., I2C) must be accessed by load/store byte instructions
  output [31:0] wb_adr, // lower address bits
  output [31:0] wb_dat_w, // databus input
  input [31:0] wb_dat_r, // databus output
  output wb_we, // write enable input
  output wb_stb, // stobe/core select signal
  output wb_cyc, // valid bus cycle input
  input wb_ack, // bus cycle acknowledge output
  input clk,
  input rst_n
  assign wb_adr = i_icb_cmd_addr;
  assign wb_we = ~i_icb_cmd_read;
  // The 32bits bus to 8bits bus remapping
  assign wb_dat_w = i_icb_cmd_wdata;
  //wire [32-1:0] wb_dat_r_remap = {24'b0,wb_dat_r} << {i_icb_cmd_addr[1:0],3'b0};
  // Since the Wishbone reponse channel does not have handhake scheme, but the
  // ICB have, so the response may not be accepted by the upstream master
  // So in order to make sure the functionality is correct, we must put
  // a reponse bypass-buffer here, to always be able to accept response from wishbone
  sirv_gnrl_fifo # (
   .CUT_READY (1),
   .MSKO (0),
   .DP(1),
   .DW(32)
  ) u_rsp_fifo(
    .i_vld(wb_ack),
    .i_rdy(),
    .i_dat(wb_dat_r),
    .o_vld(i_icb_rsp_valid),
    .o_rdy(i_icb_rsp_ready),
    .o_dat(i_icb_rsp_rdata),
    .clk (clk ),
    .rst_n(rst_n)
  // We only initiate the reqeust when the response buffer is empty, to make
  // sure when the response back from wishbone we can alway be able to
  // accept it
  assign wb_stb = (~i_icb_rsp_valid) & i_icb_cmd_valid;
  assign wb_cyc = (~i_icb_rsp_valid) & i_icb_cmd_valid;
  assign i_icb_cmd_ready = (~i_icb_rsp_valid) & wb_ack;
  assign i_icb_rsp_err = 1'b0;// Wishbone have no error response
endmodule
